| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Elso, Jocko at al,
My problem is that the spdif input circuit works beautifully with my Philips 963sa DVD Player and my Emu 1212M computer soundcard, but fails to work properly with my Musical Fidelity A3 CD player. I say "fails to work properly" because it *does* work, except the SPDIF cable has to be loose in that only the signal part of the connector is left connected and the ground part is left disconnected. Does anyone know why this is happening? The Musical Fidelity worked before with the stock CS8414 input cap set up. The cd player also works with my Denon Receiver, so I know the musical fidelity is working properly. Thanks, 300_baud Edit: This is the schematic i'm using: http://www.diyaudio.com/forums/attac...amp=1026982395 |
#2 |
Banned
How did I get dragged into this? Elso is the King of Comparators. I hate 'em. All I did was tell him how to set up the impedance properly. Give me some time to recover from my road trip before I look at it in depth.
Jocko |
#3 |
Musical Fiddle Tea as some technician friends call it often has odd ideas that may sound good in some applications but are not always universally compatible.....
One friend called their Odysseus amplifier the Audacius.... He found this beast to have too much feedback applied sending the amplifier into oscillations.... Anyway, just a guess but have you checked for DC on the MF digital out.... The denon used to "test" and isolate the problem is probably designed safe with either a transformer or cap blocking DC..... G |
#4 |
Jocko: I just read in the thread that you were somewhat involved with the schematic. Don't take it the wrong way if I misunderstood you
Tubenut: I've measured the DC offset from the Musical Fidelity A3, and it reads 0.448 volts. As per the spdif input schematic, I have input caps in between the AD8561 comparator and the CS8414. Should I have an input cap before the AD8561 instead? Thanks |
#5 |
Guys i figured out the problem,
Tubenut provided the correct clue, which was the DC offset from the musical fidelity. Putting an input cap before the AD8561 solved the problem. Take care, 300_baud |
#6 |
I should also add that i removed the caps that were in between the comparator and the cs8414. It sounds a lot better when there is a cap before the comparator than afterwards.
#7 |
Banned
SPDIF should be DC-free by definition......Of course DC affects the tripping level of the comparator. Have a 100k resistor to ground after the cap for the leakage current in/out the comparator.
Jocko, glad I am King of something! (and not King Gang Bang!!)
#8 | |
Banned
I know, I know. Jocko knew it all along....... |
#9 | |
Looks like Sponge Bob has killed another thread. |
#10 | |
Banned
You should use the improved schematic. |
| spdif input circuit help | burbeck | Digital Source | 31 | 15th September 2005 03:28 PM |
| New SPDIF input circuit. | gmarsh | Digital Source | 11 | 7th April 2005 03:05 PM |
| Dual opto/spdif input circuit ( for DIR170x ) | 246tNt | Digital Source | 0 | 19th April 2004 10:18 PM |
| I2S Interconnects, Fred, Jocko, Elso, anyone? | mefistofelez | Digital Source | 5 | 17th October 2003 04:32 PM |
| Page generated in 0.10365 seconds (78.60% PHP - 21.40% MySQL) with 11 queries |
