Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd April 2005, 02:17 PM   #1
Question Help! CDP Philips CD-204
My Philips CD-204 have a big problem : Transport always rotating when CDP power on , and can`t read any CD.
I adjust cdm-1 foucs gain/offset & laser output VR but no useful!
Is cdm-1 laser head fail?
How to do further trouble shooting?
Please help me! Thank you!
Old 3rd April 2005, 04:08 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
I've seen this in many PC cd-roms. It is usually linked to the faliure of the +5V regulator that's feeding the motor control circuits. Most of the time it isn't repairable because usually the chip that controls the motor is fried and not easy to obtain.
Old 3rd April 2005, 09:00 PM   #3
TDA1540 is offline TDA1540  Netherlands
TDA1540's Avatar
It's a problem that occurs often.
(in my experience) It is always cured with a blanket replacement of electrolytes together with new regulators and a check for dry solderjoints.
You can spend weeks,checking opamps and chips etc,but the above will probably be enough..
Start with checking the soldering.This is cheap and often does the trick.also add a wire between the groundplanes near the microprocessor on the servopcb.
Once again,a working cdm0 or cdm1 is not likely to deteriorate overnight.Uptil now,I have mainly encountered dead lasers in players that had been "modified".
In 12 years of 14bit addiction,I have once (!) seen a player that had certainly worn out it's laser.The rest had been killed by an ESD.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
Page generated in 0.06534 seconds (76.11% PHP - 23.89% MySQL) with 10 queries
