Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st March 2005, 05:47 AM   #1
tubenut is offline tubenut  South Africa
tubenut's Avatar
Default OPA637 or 627 for I/V on non O/S 1541
Hi all
I believe the difference between these two op amps is their stability at unity gain vs high gain (greater then 5)...
Which of the two would be best for I/V stage?
I am burning in 627 with a burn disc on repeat at the moment.
Is that the ight choice?
Old 31st March 2005, 06:35 AM   #2
ABO is offline ABO  Netherlands
When used as I/V converters, the loopgain is unity. This means that the opamp must be unity-gain stable.
The opa637 will not be stable in this application.
Edit: it's not the loopgain that is unity, but the feedback factor b. In normal applications, the gain is 1/b, which is unity in this case.
Old 31st March 2005, 06:46 AM   #3
tubenut's Avatar
Thank you. I made the right choice from memory then. I struggle a bit with the search feature, I normally get best results from this forum but wih google... I just did this and have established that the 627 is a good choice. I do however need to remove a compensation cap if it is in the player. 22-47 pF apparently. Is this connected across pins 5 & 8 on a 5534?
Old 31st March 2005, 08:35 AM   #4
analog_sa's Avatar
Pin 8 on 627 is not connected internally so it shouldn't make much difference.
Old 31st March 2005, 09:12 AM   #5
Terry Demol's Avatar
It depends on the OP Z of dac. For example PCM63 = approx 1k
so if FB resistor = 2k then you only need to put 1k from dac OP
(-IP opa) to gnd and it will be stable. Usually 637 will be stable
+5 or -4 gain.
The disadvantage is you can not use any LPF on I-V
cheers,
Terry
FS: OPA627 and OPA637 - ap/bp skaara Swap Meet 5 22nd March 2009 09:49 PM
OPA627 and OPA637 bigmike216 Swap Meet 29 6th February 2006 11:42 PM
I'm looking for OPA637 tschrama Swap Meet 9 11th December 2005 04:42 PM
1541 passiv I/V idea & 1541 S1 found, no A ! Bernhard Digital Source 6 9th April 2004 09:18 AM
Page generated in 0.06192 seconds (81.92% PHP - 18.08% MySQL) with 10 queries
