Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st March 2005, 11:44 AM   #1
bans25 is offline bans25  United States
Default Profesional to consumer line levels and back!
HI all,
I am new to playing in the audio / video world so forgive me if I ask dumb questions! .
Currently I am using a TI AIC23 ( http://focus.ti.com/lit/ds/symlink/tlv320aic23b.pdf ) audio codec with consumer line level inputs and outputs.
What I need to do is make a PCB that will convert these I/O's to interface with Professional equipment (+4dbu).
So I need to PAD the input to the codec (Professional line level ----> Consumer line level) and then I need
to amplify the output of the codec (Consumer line level ----> Professional line level)
Of course this all needs to fit on a PCB 3" x 3" and be low noise!
anyone have any ideas?
Any suggestions are greatly appreciated
Old 31st March 2005, 04:08 PM   #2
sync40 is offline sync40  Mexico
What is exactly the final application of your system? I am designing with that same codec and a DSP. You should decide first if you want balanced signals -independently of level- which can be accomplished with only a few parts. Did you assemble the codec and it is operating yet?
Old 31st March 2005, 04:12 PM   #3
And of course it matters if your system has an analog frontend with bipolar supplies. You should do an ac-coupling to remove any dc offset and then apply a dc offset intentionally at 1.65 volts (the codec runs at 3.3 vdc).
Old 18th April 2005, 12:01 AM   #4
I am also interfacing this to a DSP TI DM642.
I have the first version of card running, but new requirments mean I have to support both Consumer, and Professional line levels (right now I am only Consumer). I do not have to support balanced, only unbalanced.
Old 28th April 2005, 06:44 PM   #5
Besides the consumer and pro levels I had discovered that the TLV320AIC23B is really a 16 bit device (I always suspect that because the 90 dB stated in the datasheet is too much low for an 24 bits device). The datasheet does not mention anywhere about the real resolution, but the TI page states as a 24 bit part. I understand that because it its a sigma delta the real resolution does not matter if the dynamic range can be acheived, but I would prefer that TI will be clear about this.
Converting pro audio signal (1.23v) to consumer line level (0.31v)? steve71 Solid State 26 19th November 2008 09:10 PM
Professional/consumer levels ADC and headroom sync40 Digital Source 0 21st May 2005 03:55 PM
Professional to Consumer line level converion and back! bans25 Analogue Source 2 2nd April 2005 09:44 PM
Professional to consumer line level conversion on PCB bans25 Chip Amps 0 31st March 2005 11:44 AM
What are the correct output line levels for unbalanced & balanced? Brian Guralnick Digital Source 4 25th October 2002 06:27 PM
Page generated in 0.07809 seconds (73.80% PHP - 26.20% MySQL) with 10 queries
