Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th March 2005, 07:01 PM   #1
Default Low-Cost Audio Delay Line Uses 1-Bit ADC
I have come across this link in search of an simple audio delay line.
They claim it works, but in simulations I don't see any pwm-like signal, it just acts like a high-pass filter, just as I suspected the first time I looked at the schematic.
The only thought that comes to my mind is that they use the unstable nature of the comparator to create a pwm signal by having it oscillate.
Does anyone know?
Old 28th March 2005, 07:33 AM   #2
sync40 is offline sync40  Mexico
It may look ok, but there are some issues that may arise by using a 1-bit conversion. If you are trying to experiment with a low-cost digital delay, may be you should try the 8-bit ADC0820 from National Semiconductor.
Old 28th March 2005, 06:54 PM   #3
wimms is offline wimms  Estonia
The comparator must be latching, or left Rx must be connected to Q of the first flipflop.
Old 29th March 2005, 10:10 AM   #4
I wanted to experiment using a 20 mhz PIC16F84A and using some sort of sigma-delta conversion to get the data in the pic and storing it for 400 µs before sending it out again to make a digital crossfeed for my headphones.
This seemed an easy way to start since I already have most of the components laying around.
However I can't figure out why the comparator should produce a pwm signal in this configuration.
Wat is a latching comparator anyway? I couldn't find any usefull information about wat is is.
Old 29th March 2005, 10:32 AM   #5
The circuit from the link will definitely NOT work.
If one takes the feedback from the output of the first flip-flop then we have a delate-modulator which gives some improvement.
The way the circuit is originally drawn we only end up with the input signal transformed into a rectangular and then being delayed.
The best way would be to use the low pass filter(s) (or even better integrator(s) ) is in the forward path of this modulator circuit and thus building a noise-shaping delta-sigma modulator.
Charles
Old 29th March 2005, 02:56 PM   #6
I recommend that if you are using a PIC may be it worth trying a real ADC and some static external ram. That way you could do very long delay times if you wish. Also you could make the regeneration, mix, and level computes right in the PIC itself.
Old 29th March 2005, 03:20 PM   #7
The circuit was described in the link. It is delta-modulator (not delta-sigma). It is not pwm signal btw, although it looks like one.
Latching comparator is basically comparator with d-flop built in, connected like the first dflop right next to comparator in this circuit. I believe it is misprint and it was implied to take feedback from the dflop.
You need output from comparator to the RC have exactly same shape as that of after delay line. Then both RC's behave identically, and as comparator forces left RC to track signal, so will the other.
Why would you like to cripple the sound with such el cheapo when you can have decent crossfeed with analog means?
Old 31st March 2005, 02:03 PM   #8
Because I want to experiment with different delays, changing delays to give a moving source etc.
But this thing just converts the audio waves in to square waves and passes them through a lowpass to get sort of sine waves, is that right?
Well that would be of no good use to me, I guess I have to use a triangle wave generator an fast comparator.
Old 19th April 2005, 04:53 AM   #9
Default error in schematic
The schematic for the article that you pointed to had an error.
The first RC should have been attached to the output of the flip-flop, not the comparator.
If you fix that, then all should be well. You will have to use a pretty high data rate to get this to work with reasonable fidelity. Overall, the data rate required for a 1-bit delta modulator without any adaptive capability is significantly higher than the data rate from a comparable n-bit A/D. If you add adaptation, then the bit-rate can be very low (~32Kbps for telephone quality).
One-bit AD's such as this are often used high quality audio data streams because anti-aliasing can be avoided during conversion (remember that very high sample data-rate?). The rates can be daunting, however. For example, if you want to have the equivalent of 16 bits with 1 V pp signals, then you are limited to digitizing signals with a slew rate of less than 30uV / dt. A 1Khz 1V pp sign wave has a max slew rate of 1000V/s which covers 30uV in much less than a microsecond. In fact, you need a cool 33M samples per second to meet that spec. Real systems get by with less than this because perfectly full scale sine waves don't happen.
Audio Delay 0-20 millisec DIY?Matching miked and line signal majshumlan Instruments and Amps 4 12th December 2008 07:36 AM
Esl 63 what type of coil for the delay line? hilbren Planars & Exotics 25 10th December 2004 04:59 PM
Line level signal delay circuit wigginjs Solid State 3 26th September 2004 02:51 PM
Line level signal delay circuit wigginjs Parts 2 24th September 2004 11:36 AM
Group delay of a transmission line? 454Casull Multi-Way 4 8th July 2004 02:34 AM
Page generated in 0.10344 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
