Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD player not recognizing disc
Old 26th March 2005, 01:56 AM   #1
jarthel is offline jarthel  Australia
Default CD player not recognizing disc
When I insert a CD, it just say "No Disc".
It was working 1 minute and suddenly the player stop working.
I opened the chassis and have traced the wires for the motors.
When I open the tray, the voltage going to the tray motor jumps from 0V to -2.5V. When I close it, it jumps from 0V to +2.5V.
I know that for a CD to be recognize, the player does an initial spin after closing the tray. This is not happening for my player. When I measured the voltage going to the motor that spins the CDs, it remains constant at 30mV.
Any ideas?
Thanks for the replies.
ps. from memory it uses the PHILIPS CDM1210 transport if that helps
Old 26th March 2005, 04:33 AM   #2
hacknet is offline hacknet  Singapore
its probably a wonky lens. the symtoms all sound right...
Old 26th March 2005, 10:40 AM   #3
Would cotton with some isopropyl alcohol works?
I still have my doubts the lens is at fault. For the player to recognize the CD, the CD spins for a short time after the tray is closed. During this spin process, the lens would then works its magic to recognize that the CD inserted is an audio CD. Since the CD is not spinning, the lens is never given the chance to work.
These are just assumptions though but it seemed logical to me.
Old 26th March 2005, 04:14 PM   #4
tubenut is online now tubenut  South Africa
tubenut's Avatar
Default Depends...Check the limit switch, also some mechs focus first, then spin like CDM9
whereas CDM4 spin before focus.
Please check the limit switch(es) on the loader tray.
The switch is what initialises reading of TOC.
Good luck
Old 26th March 2005, 09:32 PM   #5
Default Re: Depends...Check the limit switch, also some mechs focus first, then spin like CDM9
Good luck
where will I find them? How will I identify this switch? Thanks
Old 26th March 2005, 11:02 PM   #6
tubenut's Avatar
Look near the front and back top right edges of the loader (CD face plate facing you). I am not familiar with the 12.XX versions of Philips lasers.
Look for 3 brass terminals. Generally only 2 terminals are wired up.
If you manually slide the tray open and closed, look for a plastic "finger" that gets pushed in and out. CDM4 uses 2 switches, one to sense open and one senses closed. CDM9 does this with one switch at the top front right of the loader.
On the CDM4/19 this switch is a PCB mounted push button below the mech linked to the tray with a complex lever system.
Sliding the tray in and out and looking carefully at what moves and pops in and out of place there should be a good chance to ID the switch. Look for wires going to the PCB from the mech. There are only a few sets:
Spindle motor, Tray motor, Laser (but that is a foil) and the tray switch (if not a pcb mount affair)!
If you want to clean the lens use distilled water, isoprop can take some protective/glare coat of the lens according to some on this forum!!! If you have none at hand, boil a kettle and catch some steam on a cotton bud..
Old 27th March 2005, 12:57 AM   #7
thank you. I'll try that
CD player not recognizing discHide this!Advertise here!
Disc Tray problem on DVD player. ashok Everything Else 2 18th September 2007 05:48 AM
Arcam Alpha 7SE CD player not recognizing discs gazsp Digital Source 3 3rd August 2007 07:51 PM
Converting CAL CL10 5 disc player to a single disc player stoolpigeon Digital Source 0 27th May 2007 01:25 PM
Thorens Disc Player exurbia Analogue Source 2 30th May 2005 09:39 PM
CD Player doesn't detect disc sometimes Gartak Digital Source 4 3rd January 2004 11:58 AM
