| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Im currently using an old cd rom as a cdp with a LM4780 chipamp.
What difference to the output will there be if any , should i change from the headphone socket on the front . This system is currently in the workshop, and i use an old Rotel 820 as the main amp until the chipamp enclosures finnished. But when testing the chip amp i noticed that the cdrom humm's slightly. Would this change if i used the audio out socket on the back of the cdrom.
#2 |
Is it using old computer power supply to cd-rom for power source?
#3 |
Is the amp hum or the cdrom hum?????
If the amp hum,should be a ground loop problem. |
#4 |
Yes im using an old power supply from an old large disk drive i found at the local dump. There's no hum what so ever from the chip amp when i use my sony md (pocket Type ).
| Any one know this DVD/CDROM KIT ? | ECBLN | Digital Source | 0 | 17th May 2008 07:05 PM |
| What's your CDROM player look like?? | Leolabs | Digital Source | 3 | 24th November 2006 12:07 AM |
| Different CDROM,different sound?? | Leolabs | Digital Source | 1 | 20th August 2006 01:54 AM |
| CDROM control kit | Lupulroz | Swap Meet | 35 | 13th August 2006 05:39 PM |
| Anyone knows NEC CDROM? | omar | Digital Source | 2 | 8th January 2004 07:45 PM |
