Marantz CD63 & CD67 mods list - Page 998 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th May 2008, 03:46 PM   #9971
Fidelity Audio's Avatar
Yes there is also the two -4V v refs that take the supply from the -5V L/R digital so 8 regs maybe ideal but not yet lol.
It is a very different dac to the 63 one. And I'm looking forward to getting it all working to a proper level.
Tests with the discrete first and then transformer fitment.
CD72 cool loads to do there, I had a CD94 last year for repair and it had loads of voltage rails and chips. Sounded quite nice for its age, loads of bass weight.
Brent
Old 16th May 2008, 03:55 PM   #9972
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
It sounded amazing. I want one, but clocked and with some new caps.
Simon
Old 16th May 2008, 04:36 PM   #9973
avr300 is offline avr300  Denmark
avr300's Avatar
Originally posted by 6h5c
The drawback of a TDA1547... so many supply pins! You could use even more if you like . Is it also surrounded by voltage dividers in your CD17 Brent? I'm working on a CD72mkII and have the same problem .
Ray
And so is the CD950 from Philips.
Yes, 8 regs, that's the number.
I have a 11M Flea here, so I think it must be the next move, getting that into the CD950.
Old 16th May 2008, 07:08 PM   #9974
You all know I will fit 8 regs, I just wont be able to help myself LOL
Brent
Old 16th May 2008, 09:01 PM   #9975
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
I know I would !
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 17th May 2008, 09:03 PM   #9976
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi guys!
Hope you're well and I'm here to post some very simple things I've done to keep my CD53 "up to date and neat" for now.
• Gold plated RCAs, look gorgeous, don't think it makes any difference but at least my CableTalk Brodcast3 fits thighter. Should bring what instead the OEM?
• More damping at the dead end of tray, a bit more damping is nice but I have to press and flatten it a bit for it's touching the frame and rattles annoyingly when the tray moves.
• One sheild on the DAC's top, one one the TX, both made from sheild used for RF noise one an industrial cards/PSU, under is plastic film and outer a layer if copper. Brings what beside the fact I've used unused material that should be not put to trash?
• Maybe the main upgrade is Vibrapod feet, my furniture is simple and does dance with music. I'm waiting for some more for my Integrated wich slants on the TX side with OEM feet
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Plugged all back, some hours later put a first CD and... find nothing new, maybe a bit harsh at the very begining (BG and friends not fully "ready"?). Finally not, almost nothing but a bit more focused on bass, wich are not at their highs withe the Quad 11L... anyway, Im' not fully used to the "Blu-Tacked" Quad now
So that's it, what I should I have been waiting for with these upgrades?
Originally posted by rowemeister the transformer is the same as in the 63KI but thats not an issue as I will be riping that out.
Brent
Hi Brent, will you sell it then?
That's all for now folks!
Happy 10.000 Ray
Matthieu
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 18th May 2008, 11:52 AM   #9977
SimontY's Avatar
Hi Matthieu,
I found a little more detail and a slighter smoother sound from using the better RCAs. My old ones were quite worn and old, however.
The other mods weren't likely to do much, other than the feet, which won't neccessarily be a good change.
Simon
Old 18th May 2008, 06:42 PM   #9978
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Matthieu
Gold plated RCA´s with "real" teflon insulation really can make a difference but it only gets perceivable after some time. Cables and RCA´s must settle.
I think you should add some TX to your machine.... 1 TX for servo sregs and 1 TX for analog opamps.... That makes a really big difference.
Almost on the 10.000
Ricardo
RC
Old 18th May 2008, 07:36 PM   #9979
Malefoda's Avatar
the RCA are good ones, these:
http://www.audiophonics.fr/embase-rc...?cPath=119_230
said to be real Gold plated and teflon.
Ricardo I will, maybe this winter cold's night like last year
And also a dedicatet TX for my integrated at the preamp section (and maybe BrentRegs ).
Thanks guys!
Old 18th May 2008, 10:46 PM   #9980
Malefoda's Avatar
Also,
will order BG from Lee's and wanna know if I should buy one or two to place in my CDP ( only got 4 of them around opamps).
Here is my setup, any BG around analog of DAC?
And wich value? I'm running lean these days, gotta save fuel... 47/16 or 100/16 or 220/16 std.
Lee, I want a discount as a good customer
Thanks fellows!
Matthieu
Copyright ©1999-2017 diyAudio
