Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 9th May 2008, 01:59 PM   #9921
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Nice overview, peufeu.
Very clarifying to read, puts things back into perspective :-)
What kind of analyzer are you working with?
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 9th May 2008, 02:46 PM   #9922
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default Re: Re: Really joyfull
Originally posted by rowemeister
I'm glad you like the reg
Hi Brent
Hope your new home is according to youe expectations.
I really do like the spower...... If I could, (€€€) I would replace ALL regs by those.
Now I am collecting parts for the dedicated PSU for analog dac and digital dac.
I have been looking to your pics and see you are using 10000uF BHC Aerovox ALT22A103CB040.
Looking ate the specs, I found that ESR is a bit high (50mohm).
Can I use two Pana FC 25v 4700uF instead ? (ESR is much better at 15mohm each and I would get a much higher ripple current at 7.5A combined)
Best Regards
Ricardo
RC
Old 9th May 2008, 03:13 PM   #9923
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Thanks Ricardo
The BHC caps really do work well (Naim use these).
Brent
Old 9th May 2008, 04:36 PM   #9924
nhinstruments
RCruz's Avatar
Hi Brent
That settles it then.... I will need two BHC.
Now about the Spower... Can you please inform waht is the ic that looks like a reg ?
It is the same size but all plastic and I can not read any lettering.
I believe the trick in these regs is the speed they can deliver but I know nothing about it´s layout (secret is businesse´s soul!!)
Ricardo
RC
Old 9th May 2008, 04:38 PM   #9925
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
The big thing is a transistor. If you heatsink it, she will deliver up to about 6A of current!!
Old 9th May 2008, 04:39 PM   #9926
nhinstruments
RCruz's Avatar
Awesome!!!
RC
Old 9th May 2008, 04:40 PM   #9927
nhinstruments
RCruz's Avatar
Originally posted by gareth
Is there a different (more solidly built) transport available for the 63/67? I have somewhere about another Philips transport which is cast aluminium or something.
Gareth
Start looking here:
http://www.pinvan.com/CDMPRO/cdfaq.html
RC
Old 9th May 2008, 09:45 PM   #9928
gareth is offline gareth  Wales
gareth's Avatar
Originally posted by RCruz
Gareth
Start looking here:
Thanks for the link RCruz, but which of these would I be able to fit into a CD63? Would I have to modify the microcontroller or any othe r parts in the CD ?
Gareth
Old 10th May 2008, 12:42 PM   #9929
nhinstruments
RCruz's Avatar
Gareth
You surely have to make major mods to the CDP.
The pro model is a top loader so you can not use the stock drawer.
As for the connections, I believe you can just plug it to the main board but not sure .....
RC
Old 11th May 2008, 11:34 AM   #9930
ian21 is offline ian21  England
Default output resistance
Once again asking the forum and members for help .. the problem is this.
The left channel has sounded ' soft for a while on checking resistance at rca's found 100k on right side, from r662 i think but 34k on left. Aha i thought r661 gone , got 34k across that... changed it but no improvement. Sounds simple so far.. removed link u217 to isolate output filter.. fine 100k now at L rca. Have since checked every component i can think of and can not find the cause. I guess its painfully obvious to some but cant nail it. I suspect some parallel path to ground coz on the dmm the 34k slowly rises as if charging a cap, so c611/613 have been out to check and ok as are the bypass caps
If anyone can point me in the right direction i will be most gratefull.
Many thanks in advance.
Ian
p.s.
It's a fairly well modded 67
also get on op amp pin 6 to ground 128k R, 47k L -- pin 7 to ground 100k R, 34k L. ??
Marantz CD63 & CD67 mods listHide this!Advertise here!
