Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 1st May 2008, 06:22 PM   #9881
ian21 is offline ian21  England
http://www.diyaudio.com/forums/showt...39#post1498839
no probs all sorted ... well modded cd67 but now with new clock sounds superb superb. thanks simon thanks brent
woohoo
Ian
Old 1st May 2008, 07:10 PM   #9882
ondesx is offline ondesx  France
OK thank you for your answer... I'm presently using my MacBook Pro as a player either for ripped audio, CD or radio stations on web. The improvement in audio quality is just incredible ! The Apple CoreAudio is simply unbelievable and light-years above most so-called High End players...
Finally, I'm not really motivated to invest time and money in this old CDR 620 recorder/player, even it was a very expensive unit : the launching price was more than 3000 Euros...
All the best,
OndesX
Old 1st May 2008, 08:12 PM   #9883
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally posted by Thomo
Ricardo, the output pin of the reg should connect to u199. The easy way is to bend the leg and just solder straight onto u199.
U200 should be cut/removed as this originally supplies u199 with 5v.
Hi Lee
I will remove U199 and replace it with a small pcb with two pins.
Both pins will connect to the sreg output of course.
This small pcb wil have the sreg + output cap..... 220uF BG or 470uF BG.... I did not make my mind yet.
Ricardo
RC
Old 1st May 2008, 08:25 PM   #9884
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
I would use 2x 220uF BG minimum but 2X 470uF BG is fine.
Brent
Old 1st May 2008, 08:28 PM   #9885
Jim
The divider circuit (D1) will gain you much more detail. Not quite as much as you would get with a full C1 but its also much cheaper.
Brent
Old 1st May 2008, 08:56 PM   #9886
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
woohoo
Ian
I'm so pleased you got it working! And reclocking is the way forward on these machines
Simon
Old 1st May 2008, 09:48 PM   #9887
nhinstruments
RCruz's Avatar
Hi Brent
I was thinking about 1 x 470uF BG on the spower output as I already have 2 x 2200uF Rubycon MCZ on CD15 and CD16...
Is 470 enough ?
More than that will cause placement problems.
Ricardo
RC
Old 1st May 2008, 10:20 PM   #9888
SimontY's Avatar
Originally posted by RCruz
Hi Brent
Is 470 enough ?
Ricardo
I'd have thought you could use even less as you're only powering one little circuit. It will still work and sound great. Quality over quantity!
Old 2nd May 2008, 07:13 AM   #9889
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi Ricardo, if you are fitting the reg onto u199, you don't need the BG on the Spower output as cd15 & cd16 are there and close enough to do the job.
Lee.
Old 2nd May 2008, 07:19 AM   #9890
I assumed Ricardo was fitting the BG to CD15 CD16.
Personally I would remove the MCZ and replace with 2x 470uF (2x 220uF minimum)
Brent
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
