Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 15th January 2008, 07:00 PM   #8901
martin clark is offline martin clark  Europe
Put one or two ~10uF 250VAC lighting capacitors across live - neutral.
These can make thing worse..!:
http://www.acoustica.org.uk/other/filter.html - scroll down to 'Don't try this at home.' Not picking on you Simon - just pointing out that these things are incredibly context-dependant.
You could also throw some Y-rated caps across L-N and L-E.
Not more than 4.7nF please - any more risks serious shock from casework if there's any problem in your earth installation.
Old 15th January 2008, 08:14 PM   #8902
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Sure, I'd better add that adding capicatance worked for me, in 3 houses, with varying systems. I didn't measure anything or study the technical side, nor do I know why it can work or in which contexts it may not.
Actually, I thought I'd not hear any difference with my current cheap bookshelf speakers, so I didn't even plug in my filter till recently. I was pleasantly surprised when it had the same effect again!
Simon
Old 15th January 2008, 08:27 PM   #8903
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
I've fitted Ray's CD63 things in the main:
- Place varistor S20K250 directly on mains pins of IEC socket or on mains terminals on PCB.
- Insert common-mode filter (Farnell 353-2331). Remove U242/243/245/246 and insert filter instead. Place two class X or Y capacitors 4,7n/250Vac across mains before and after filter.
My main is really bad, should be rock solid 238V like my former flat in town, now it's dancing from 215 to 220 with many noises ( I can tell when the washing machine is on... ).
I trust Ray for his good adivces, as my palyer sounds very good, but any backdraw of the filter?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 15th January 2008, 08:31 PM   #8904
SimontY's Avatar
It probably won't be helping the sound, nor will it be ruining it.
Sadly the fluctuations can't be helped short of complaining to the electricity supplier (good luck!) or buying a mains regeneration gizmo (expensive!)...
Unless some of it is caused by faulty or inadequate wiring in your house, which seems unlikely.
Old 15th January 2008, 09:31 PM   #8905
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Good filters will have various capacitors fitted with decent clamping components. On LN LE NE with resistors to aid discharge.
Brent
Old 16th January 2008, 04:37 PM   #8906
dublin78 is offline dublin78  United Kingdom
Hi Guys
I have finsihed my CD63 project (for now).
Thanks for your help.
See this thread: http://www.diyaudio.com/forums/showt...88#post1402288
Apologies for bastardising a perfectly good unit and for being too lazy to improve the output and DAC stages.
Old 16th January 2008, 05:27 PM   #8907
riccardo is offline riccardo  Italy
Default a decisive tweaking
Hello!
There is someone who want to try THIS?
For a simulation:HERE
at last, this is the Ray's page
The tweak is good for both series: 57/67 and 63.
There are only little differences in the output analog stage of both series, and the tweak is great for both.
I try this, and other, in this 3D of my forum
Thanks to Ray, Mauro, Loesch, and Tnt Audio
Ciao
Riccardo
Old 16th January 2008, 06:48 PM   #8908
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default Re: a decisive tweaking
Originally posted by dublin78
Hi Guys
Your work is an inspiration for me.
Congratulations.
Originally posted by riccardo
Hello!
Riccardo
Thank you for this tweak.
Ricardo
RC
Old 16th January 2008, 07:34 PM   #8909
I hope youžll give us your feedback about this tweak.
That is great, imho.
Anyway, don't forget that this idea it isn't mine, but of Mauro Penasa
Old 16th January 2008, 07:58 PM   #8910
nhinstruments
RCruz's Avatar
I will...
Marantz CD63 & CD67 mods listHide this!Advertise here!
