Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 15th January 2008, 10:44 AM   #8891
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Originally posted by martin clark
The only only other example I'm aware of is the SLim Devices transporter, which has ALWSR topology built-in a couple of places.
...to feed NE5534 op-amps...
..and it got a quite a few luke-warm reviews.
Old 15th January 2008, 11:14 AM   #8892
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
It really makes me laugh what opamps are fitted in expensive or higher than normal products.
Brent
Old 15th January 2008, 11:29 AM   #8893
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Brent
Yes, and as we've seen a valve output stage seems like a license to double the asking price. It's all about perceived value and how that perception changes our awareness of the sound being produced.
We know that reclocking the DAC and servo is a much more fundamental change in our players but it's not quite as sexy as two glowing rods of high voltage hype, therefore not as marketable.
Re. power supplies, I suppose the manufacturers reach excellence in power supplies by good isolation and overrating transformers (top end Naim especially), but is there aaaany gear that has ultra-low noise power? What about Musical Fidelity and their chokes??? Martin???
Simon
Old 15th January 2008, 02:15 PM   #8894
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Brent
Me too. I read a rave review on a new 1000 dac in HFW the other day, it has four crappy opamps and apparently it's awesome, better than a 1500 player! But not as good as the writers cd63KI-DP. Made me laugh.
I agree with Simon, it reall is strange what can alter your perception (like having a copper plated cd player named after you).
btw - Just moved the mains supply from the electric cooker socket in the kitchen, to the living room. 6mm mains cable and 2.5mm earth, straight from the fuse box! Sound much nicer now it's more isolated from the rest of the house.
Lee.
Old 15th January 2008, 02:23 PM   #8895
LOL so it's just microwave meals now then.
All you need now is a really good filter
Brent
Old 15th January 2008, 04:17 PM   #8896
Thomo's Avatar
Yup, Microwave meals
Anyone have any designs/ideas for a mains filter? Maybe a new thread is needed, can't be going off-topic can we, lol.
Lee.
Old 15th January 2008, 04:22 PM   #8897
SimontY's Avatar
Lee.
Yes, let's not get toooo off-topic, but I'd like to share this idea:
Put one or two ~10uF 250VAC lighting capacitors across live - neutral. You could also throw some Y-rated caps across L-N and L-E.
Then you'll want some transient diodes across L-N to clear up the spikes. Much, much better/faster than the common varistors/MOVs.
You'll hear a warmer, more spacious sound with deeper bass.
Simon
ps - disregard any ideas you might see about putting things in series with the mains, unless you can cheaply find and are prepared to live with large isolation transformers, or want to build a "balanced" mains supply such as Ray did.
Old 15th January 2008, 06:28 PM   #8898
Lee.
There are ways and means of builing a mains filter. Ours are all passive and do not add inductance. Always add a resistor across LN to discharge the caps.
Brent
Old 15th January 2008, 06:32 PM   #8899
Glenn2's Avatar
Brent
I wonder if that's why when I populated the empty common-mode choke spot on the CD-67SE PCB, the sound immediately sucked. So I took it out again and normality was restored.
Old 15th January 2008, 06:46 PM   #8900
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I had a similar experience when tried to feed my system with a computer UPS.
The sound is dead.
Ricardo
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
