Marantz CD63 & CD67 mods list - Page 850 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st December 2007, 09:01 AM   #8491
Default Re: Re: Re: Marantz CD63 & CD67 mods list
Originally posted by RCruz
Can anyone comment on this ?
I would like to try this modd but not sure of the possible outcome.
Ricardo
Hi Ricardo
If you use good op-amps you can leave R619, 620 (10 Ohm), remove all the other stuff, and run straight to the output connectors.
André
Old 1st December 2007, 01:45 PM   #8492
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default Re: Re: Re: Re: Marantz CD63 & CD67 mods list
Hi André
Thank you for your reply.
As I damaged some lines in the PCB when removing the output caps, this is very good news because I will bypass everything from the 10ohm resistors on to the outputs.
These 10 ohm resistors serve what purpose ?
Can I upgrade them ?
Note:
I believe I have good opamps (LM4562NA) ?!
Best Regards
Ricardo
Old 1st December 2007, 02:09 PM   #8493
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: Re: Re: Re: Re: Marantz CD63 & CD67 mods list
Note:
Hi Ricardo,
They make sure the next stage cannot easily demand too much from the op-amps and cause instability. In reality there isn't likely to be any such problem.
If you keep them, yes you can use nice ones for a very subtle improvement. Nice resistor makes include Vishay, Kiwame, Shinkoh, Allen Bradley and Holco. I like Kiwame a lot, but haven't tried many types!
Simon
Old 1st December 2007, 02:17 PM   #8494
nhinstruments
RCruz's Avatar
Default Re: Re: Re: Re: Re: Re: Marantz CD63 & CD67 mods list
Thank you Simon
It is settled then.. I will replace them by Kiwame... Can you suggest where to get them ?
Another important issue:
The stock TX seems to have only two fuses just before the +-5V digital psu.
I have a new tx for the opamps and am trying to figure out the way to fix it and how to link it to the PSU.... Should I place a fuse in the mains ?
Best regards
Ricardo
Old 1st December 2007, 02:21 PM   #8495
SimontY's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Marantz CD63 & CD67 mods list
Thank you Simon
Best regards
Ricardo
I used http://www.hificollective.co.uk/comp...resistors.html to get mine, but I know they're available in other countries too.
I don't use any fuses personally, but it would be wise to, certainly at least for testing. Perhaps someone more experienced can comment on the rating.
Simon
Old 1st December 2007, 02:52 PM   #8496
nhinstruments
RCruz's Avatar
Thank you again.
I will install a 1A fuse just for testing.
I will bypass everything but the 10ohm hope this does not raise the output volume as the CD actually plays louder than the radio that I use for benchmark on my Meridian 101.
Ricardo
Old 1st December 2007, 03:02 PM   #8497
SimontY's Avatar
I think it will change it VERY little!
Old 1st December 2007, 03:21 PM   #8498
nhinstruments
RCruz's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Marantz CD63 & CD67 mods list
Another question.... What type of wire should I use to link the TX and the upgraded PSU to the PCB ?
I am considering building a small pcb with two 10.000uF nichicon KG bypassed with some polystyrenes and tantals after the diodes.
This pcb may have the regs and output caps also because I believe the best way to unlink the stock PSU is to remove the +-12v regs.
Ricardo
Old 1st December 2007, 03:29 PM   #8499
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I wouldn't bypass the Nichicons with anything personally. I may do it with lesser cheapo caps but the kg's are very nice indeed, i think marantz put them in the pm17ki.
Lee.
Old 1st December 2007, 03:49 PM   #8500
nhinstruments
RCruz's Avatar
Hi Lee
As I bypassed every cap in the digital area and the results are very good, I was thinking to do the same.
What about using these Nichicons in paralel with some 3300uF Pana FC just to increase the speed ?
Can you comment on the wires please ? I really need some help here.
Ricardo
Copyright ©1999-2017 diyAudio
