Marantz CD63 & CD67 mods list - Page 828 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd November 2007, 10:22 AM   #8271
Fidelity Audio's Avatar
Originally posted by avr300
Another one ready to rock.
Excellent. Looks well made too
Brent
Old 3rd November 2007, 10:23 AM   #8272
Originally posted by 6h5c
Ah, apparently the surgery worked .
More music, that's good to hear, you're welcome!
Just wait till you try some low-noise regs and other fancy components...
Ray
I second that
Brent
Old 3rd November 2007, 10:35 AM   #8273
Default ground plane
hi this may seem like a stupid question but im quite a noobie at this, if i make a circuit board for the output stage how would i fit it in the player, could i screw it down or will this mess up the grounding, if you know what i mean?
thanks
chris
Old 4th November 2007, 10:28 AM   #8274
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Default Re: ground plane
thanks
chris
Hi Chris,
You could screw it down, but most of the times there's no room for drilling fixing holes in the player's PCB without damaging the copper traces. Or you could short-circuit things with a metal bolt or nut. I usually glue a few distance studs to the underside of the PCB-to-be-added and then fix it to the main PCB with glue or small pieces of double-sided foam tape. Or I use tape on top of the HDAM cans or the electrolytics combined with some studs.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 4th November 2007, 11:39 AM   #8275
avr300 is offline avr300  Denmark
avr300's Avatar
At this latest creation, I use the HDAM cans as basis, then a layer of foam to keep the clearance and, at last, double sided foam tape to secure the circuit board.
Old 5th November 2007, 07:56 AM   #8276
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi guys. I am looking to build a discrete stage and having read above about inductors picking up noise, would like to know the best ones to use. I am looking at:
1193619 and 1077043 , any ideas which are best? Or can one of you guys point me somewhere else for better ones?
Lee.
Old 5th November 2007, 08:04 AM   #8277
Thomo's Avatar
http://rswww.com/cgi-bin/bv/rswww/se...eID=uknetscape
This one has lower resistance but same inductance
Lee
Old 5th November 2007, 04:43 PM   #8278
I assume these are Farnell part numbers not RS ?
http://uk.farnell.com/jsp/displayPro...sp?sku=1193619
http://uk.farnell.com/jsp/displayPro...sp?sku=1077043
Jon
Old 5th November 2007, 07:00 PM   #8279
Thomo's Avatar
Jon
Yup, that they are. Any ideas on the best to use? I have just made these and want to get cracking.
Anyone, what's the best way to stop the boards oxidising?
Cheers, Lee.
Old 5th November 2007, 10:21 PM   #8280
gold plating
Boky
Copyright 1999-2017 diyAudio
