Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 15th October 2007, 08:38 AM   #8001
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by rowemeister
Perhaps the SC4 is that good.
Oh dear, this thought process sounds expensive!!
Old 15th October 2007, 08:44 AM   #8002
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Originally posted by Thomo
I hope not!
Reading Audiocom's spiel about the sc4, they say it has separate on-board low noise regs for dig and analogue.
Does anyone know if there's any way to split these on the sc2 and feed them with off-board regs?
Of course it can be done, the circuit will need a good looking at but yes anything is possible.
Brent
Old 15th October 2007, 08:54 AM   #8003
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I'll take some detailed pics in a minute and fire off an email to Audiocom for details (don't count on getting any though).
Lee.
Old 15th October 2007, 09:23 AM   #8004
Thomo's Avatar
I've started a new thread for the clock thingy, so feel free to contribute, comment or anything else.
Superclock Mod Thread
Lee.
Old 15th October 2007, 09:25 AM   #8005
O rly
Brent
Old 15th October 2007, 09:31 AM   #8006
Thomo's Avatar
lol. Maybe I shouldn't have bothered the amount of times this thread has gone o/t!
Lee
Old 15th October 2007, 08:31 PM   #8007
Andre Visser is offline Andre Visser  South Africa
Originally posted by navin
200 W class A? that must produce a lot of heat as well. can you share the details of your system (2.5 way loudspeaker, preamp etc..)?
Hi Navin
Yes my amplifiers produce a lot of heat, quite nice in winter. (It can be switched to class AB) The design started about 10 years ago, running class AB with Mosfet output stage. After several versions, I ended up with massive heatsinks, class A and 1kW power supplies per channel.
The pre-amp is a discrete dual mono design with balanced and unbalanced inputs / outputs with 2 x 50VA transformers and remote control.
The speakers are manufactured of 32mm MDF, it is a 2.5 way transmission line design, constructed to allow for exact time alignment of all drivers as well as the front firing port. I use 2 x Seas Excel 6.5" magnesium cone woofers, one for mid / bass and the other only on bass, and a Seas Millenium tweeter. In the crossover network I use foil coils and Hovland capacitors.
For interlinks, speaker and power cables, I use Ecosse Monocrystal cables.
André
Old 15th October 2007, 11:07 PM   #8008
SimontY's Avatar
Wow, that's an amazing setup fed by a second rate source! Time to get upgrading!!!
Old 16th October 2007, 07:05 AM   #8009
Just what I was thinking, lots of mods needed to get the most out of the system (although I would guess he has vinyl in this system too)
Brent
Old 16th October 2007, 12:26 PM   #8010
geoffgjones1 is offline geoffgjones1  United Kingdom
Default External tranny and other things..
Time for a report.....
Large external transformer for the opamps (225VA) is a success. Loads of bass, clean mid. I am going to try an 80VA, just to compare. The 225VA is a little heavy! This was to replace a small 6VA tranny. 12000uF Audio Elnas used, with ultra fast diodes, feeding schulz regs in the CD63KI.
Sound now compares well with my Linn LP12 for bass, probably even more detailed, although they do obviously sound "different". Now I will try a new PSU for the preamp in my PM17KI.
As for A class amps, I have always biassed my AB class stages more towards A class for the first few watts of output power with good effect, and much less heat! YOu have to be carefull though. I have to monitor temperatures carefully for the first few hours just in case i have taken things toooo far.
Geoff
Marantz CD63 & CD67 mods listHide this!Advertise here!
