Problem solved... had a look at the schematics and realized I just cut the output by removing the caps... Wired them, and works again.
I guess I don't need to tell you this but the difference is HUGE!
Placing becomes more accurate (not as blurry as it was) and detail improves. Very happy with my first tweak!
Hi Matthieu
I believe you made a perfect sumary of the main mods.
The LM340AT for the main +5v and the styroflex 2.2n at the decoder are really sound openers.
The LM4562 on dedicated regs are very powerfull mods (of course one needs to loose the HDAM and output caps and resistors)
PS: What type of TT are you using ?
Ricardo
Hi Ricardo!
I must have miss the styroflex 2.2n mod at the decoder while browsing this thread lastime. Which part of the decoder should I put this on? Thanks!
Eddy
Good work!
Eddy,
it's the C505 cap.
Good work!
Eddy,
it's the C505 cap.
Hi Matthieu!
Thanks for the info! I can't find the C505 in my cd67. Could it be that this mod is only for the cd63?
Eddy.
It's Lee Mong you need AKA Thomo
Brent
Orly.
I don't have any stock of BG left, I'm afraid.
We're going to miss em badly in the next few years.
Lee.
I wonder why nothing is coming in to replace Black Gates. It could be that it's too small a market for manufacturers to care about, when already there are Nichicon MUSE and Elna Silmic and For Audio parts available. I thought making BG would be profitable but maybe not enough
IMO, Ruby ZA are quite good in digital areas but in analog supplies they tend to produce a "thin" sound...... wonderfull detail with low distortion but somehow lacking in the low freq area.
What I notice whenever I've used Black Gates is a more forward midrange that is fluid and sweet. The sound is detailed in spite of a relaxed presentation. If only some other caps could confer this type of improvement
Hi Ricardo,
I've not compared them unfortunately. I'll be sure to post about it if and when I do. I might try some Silmics but it's hard to compare to something so hard to obtain. A better comparison might be vs. Cerafine, ZA, Os-con, film caps or MUSE - all nice audio-friendly decoupling caps.
Simon
Simon
Silmics are really smooth and full-bodied sounding caps with a nice, flowing nature. They are veiled in the detail department compared to Black Gate, ZA. The Silmic II does have a better top end than the older "mk1" version, but is still not up to Black Gate levels. However, if ZA are too dry for your tastes, I have found a combination of Silmic's directly after regs and ZA right at the loads is a really nice combination when BG are unavailable.
I really like the Nichicon Muse caps, these seem a little more open sounding than Silmic, but I haven't directly compared them.
Cheers, Lee.
Cheers, Lee.
So a sprinkling of "salt" here and "pepper" there may be the best way to proceed! Then perhaps we'll add some balsamic vinegar (os-con SEPC) to complete the feast.
We could discuss smoothing caps too but I can't add much to that one except to say bigger (physically) seems to sound better and bigger uF is a bonus.
Simon
Simon
- Digital Source
- Marantz CD63 & CD67 mods list
