| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#631 |
One Seriously Addicted to Audio and Electronics
And now for something completely different....
What's the status of our custom tranny project? Is it just me, or has everybody's enthousiasm regarding this idea cooled down a bit? Or am I just being impatient Michael, you were going for a quote on a 50VA, any news yet? Regards, Ray. |
#632 |
Magneto the Gravity Man
Hi Folks.
After a short delay ( I broke my soldering station ! It's going and sounds excellent. Really good bass, mid and top a bit recessed - need to play around with the filter caps a bit - I used slightly different (higher) values to Thorsten's. Also the amp is on long leads from the cd-p - 12" or so and it's only in mono. I used 12k anode resistors not dual cascode but I will try later and see if it makes any difference. NOTE THE VOLTAGE BEING USED !!!!!!!!!!!! 50v I have taken the B+ down to 20v. The output drops and distortion starts at this point but from 25v up i cannot hear any difference. I will post a circuit when I have drawn it. Andy |
#633 |
quick sketch - most will be familiar already
#634 |
Excellent dude!
The tubes are starting to be common practice in this thread I'm about to order some parts for it and build the passive filter part on the players PCB. Wow, 50 volts is low! This can be done with a standard 2x24V tranny. I did notice the circuit goes on for a long time when I switch-off my power supply. What tubes did you use? Do you have a (too) high output signal? Lose the 2k2 resistors and try the CCS FET in the tail. It will bring balance in the circuit, cuz the resistor is not much of a constant current. Regards, Ray. |
#635 | ||||
I am putting all the stuff on the board and using links to the Marantz PCB ( DAC output ). Quote:
Now that it has been running for some hours, it seems to have 'run in' and now sounds better. 'She who must be obeyed' says it sounds really good! I realised that the lack of prescence etc was due to the fact that it is MONO!!! and 1 channel only !!!! I have just bought a Marantz cd53 ( no HDAM to remove ) for future experiments!!! Andy |
#636 | |
? Cool! When I receive my parts i'm going to try it on 50V too. I have two PCC88's here that I can use. It has a bit high mu for this application, but it is better suited for low-voltage use. I'm curious how the small valves will do. Did you measure any noise residue at the output that I experienced earlier? Ray. |
#637 |
low voltage for tubes
this may give some ideas http://headwize.com/ubb/showpage.php...d=5395&fpage=2 allan post 17
Indecision makes the world gone round. Maybe |
#638 | ||||
Andy |
#639 |
Hi Allan,
Thanks for the link! I didn't think of the headphone-guys. They are used to using tubes at low voltages for a long time Your earlier remark about the HDAM circuit got me thinking (again...). Maybe it can be changed as you said, into a discrete buffer without any feedback, to buffer Thorstens filter circuit. I'm going to look into that and do some experiments. I got some inspiration when I found this circuit again at Ultranalog. The differential input stage and current source are already there in the HDAM. Regards, Ray. |
#640 | |
Did you use a 2SK170 for the CCS and did you have to select it for the 4mA? I have a lot of 2N5484 - I suppose i can use them? Andy |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| thierry67 |
| Page generated in 0.22511 seconds (56.12% PHP - 43.88% MySQL) with 11 queries |
