Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th February 2006, 07:15 PM   #621
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally posted by 6h5c
Andy,
How's your tubestage going?
Ray.
Hi.
Waiting on some components - should have it running at the weekend.
Andy
Old 10th February 2006, 10:47 PM   #622
Fidelity Audio's Avatar
I have been listening to my HF RF and Servo upgrades over the last two days.
I will say every single part of the music has improved.
It's not like when you change the op amps or when you do the HDAM it's more subtle.
The treble is more controlled, the mid is smoother and the resonance in the bass is a lot better.
I do believe this mod will only truley shine once the op amp hdam regs clock stuff is done first. I think it would be wasted otherwise.
These three mods need to be done on the 63 as all three circuits are connected to each other.
I recommend........
Now roll on servo hf rf reg pcb lol
and valve output
oneday it wil all end
Old 11th February 2006, 10:38 AM   #623
poynton's Avatar
[i]...............
................[/B]
I was thinking overnight that one area we have overlooked so far is the type of plastic that the front panel is made of!
We could have some custom made in carbonfibre composite with copper interwoven to provide a Gaussian screen.
Oh, the vans just arrived with those nice men in white coats....
Old 12th February 2006, 04:03 AM   #624
awpagan is offline awpagan  Australia
Default ooop's
now i've done it
i'am going to have to read this whole thread
I've been looking for another cdp to mod.
already have cd850 (yes the classic)mk1 i've been modding eg clock.opamps mute etc
Am going to do psu, i2s out, etc
just needed spare cdplayer just in case i stuffed it for a while
i just got myself a cd67
very good condition, not very old or used.
sound? not bad, but is totally stock
Has a lot of promise.
Could be an interesting project?
which one can better the easiest and/or overall.
allan
Indecision makes the world gone round.
Maybe
Old 12th February 2006, 11:02 AM   #625
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Hi Allan,
The CD67 is a very interesting project indeed. I don't know the CD850, but the TDA1541 DAC is very nice. If you search this forum you will find lots of info on it.
You can find some interesting info on both DAC's in Thorsten's article.
In my CD57 mod's list you will find an overview of lots of mod's on this player. The CD57 uses the same PCB.
You'd better take some time off to digest this thread .
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 12th February 2006, 11:32 AM   #626
yeh ray
up to post 120
"Hmm, looks like guano to me...."
I've often said my bro's electric welding looks like pelican Guano to me.
like my soldering used to be
or still is
the cd850 uses decoder saa7310 dig-filter saa7220 dac saa7321
but i like them
the cd67 uses decoder saa7372 filter+dac sm7372
just found data sheet for saa7372 has i2s out? future reference!
just a thought about the hdam circuit
how about bypass opamps and use the fet for dac?
similar to pass's xbosoz
or pass's IV output stage?
Maybe
Old 12th February 2006, 11:34 AM   #627
have to find the cd67 manual link
need better look at analogue out circuit
allan
Maybe
Old 12th February 2006, 12:30 PM   #628
6h5c's Avatar
but i like them
Hm, I thought it was the 1541....maybe that is MKII?
In the CD63 and 67 the oversampling is done in the SM5872 DAC, so the data out of the 7372 is non-os .
Yeah, that could be possible. But you'll have to use some kind of passive filtering. But the HDAM will not combine the signal of both outputs of the DAC.
IV stage is not possible for this DAC, since it has PWM voltage outputs
Ray.
Old 12th February 2006, 01:13 PM   #629
up to post 350 now, very interesting reading
will continue tomorrow
?your 3 pin power plug iec socket, earth or grd point
won't a star earth be useful?
every voltage is relative to earth
if no earth in cdplayer, electrons will find the lowest resistance back to earth.
maybe throught the ground on the output rca's to the amp's earth.
a thought since the earth circuit in the board is all over the place.
and before you say neutral for earth
neutral can be very noisey.
back to reading
custom transformer?
allan
ps hmmmm passive
Maybe
Old 12th February 2006, 05:41 PM   #630
6h5c's Avatar
Hi Allan,
The idea to ground the player was born from the fact that I have a tubeamp that is grounded, for obvious safety reasons. I didn't want the ground current to travel through the interlinks shield. So I decided to ground (or "earth") the player and create a second low resistance path and see what happens. With the risk of creating a humming ground-loop, but fortunately the whole setup is mouse-quiet .
I chose to ground the player at the output's ground star-point. If you take a look at the layout you can see all the PSU ground traces go there. The ground layout is not the best in this player, but this seemed like the only sensible place....
Ray.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
hotiron
Page generated in 0.25198 seconds (64.70% PHP - 35.30% MySQL) with 11 queries
