Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th February 2006, 01:38 PM   #591
Fidelity Audio's Avatar
C501/502/505/507 silvered mica
C504 to 16V 220uF Silmic
R501/502/504/506/507/509 to 0.1% Tol welwyn
Old 7th February 2006, 01:41 PM   #592
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by poynton
Most women do sound better in another room!
Oh my, that's a cracker
Old 7th February 2006, 02:11 PM   #593
6h5c is online now 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Hi Ray,
The Vref does not need to be exactly 2.5v ( I think ) but it does need to be 'clean'. These are in effect audio amps....... what effect does the psu line noise have on performance??? Cleaning it up cannot do any harm!
I agree, the actual value of the 2.5V is not that critical, as long as it's stable and clean. It will give the drivers a nice solid reference.
Pins 17, 21, 22, 26 supply the output amplifiers so could be considered analog. I think the optimum solution is to power the DAC from 3 independant 5v supplies, clock, digital & analog. Well, thats my plan!
Sounds like a healthy idea to me, separate regulators for every part. At least you'll be sure the noise is as low as possible.
The supply to the servo chip is 5v analog to pin12.
VRef is taken from the feed to pin28, digital supply!
Andy
Hmm, looks like there's room for improvement. I investigated the tracks, and it looks like the schematic doesn't match the PCB. In my player Vref is connected directly to +5V, and not through R122. Also the +5V for the drivers that is supposed to run through R122, via pin 28, is connected directly. But I think this is a good thing, the digital supply has it's own separate RC filter now.
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 7th February 2006, 04:20 PM   #594
Is there any good evidence of fitting blue/green led's inside the player (level with disc) as a way of improving things.
I have read about lots of gimicks but wondered if there is any truth in it. I understand a blue green light will have some affect on the red light of the laser but how much?
Old 7th February 2006, 05:35 PM   #595
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Y B Blue - how blue LED improves the CD playback
Andy
Old 7th February 2006, 05:50 PM   #596
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Ray:
No, I dont use some muting devices at the output, but I should
What I mean: there is some nasty noise, switching the player on and off. And some minor noise, while positioning the head.
I plan to insert relays, like you did.
I have heard this before!
However, I, like many others no doubt, recognise that the pcb layout etc is done by a router with little regard for the sonic benefits of good grounding etc.
However, we do not possess the knowledge or tools to analise and then reconfigure the pcb.
Have you modified your Ground???
If so, please pass on the information.
Yes, I modified the ground, following the recommendations from Gerald Gessner.
Thats why I cannot publish them. But here are many people involved and I am shure: you they will find good modifications for the grounding layout. Just let things happen...
Another hint (the last one): sometimes simple zener diode solutions can be the best and simplest (pin 21/22 of the DAC).
Happy ears!
Franz
P.S.
Ray: yes, nice speakers! I got them cheap some weeks ago. But I had to refoam the woofers (did it the first time). It was a ACR kit from 1988, a four way system (me as fullrange freak...)
Old 7th February 2006, 05:54 PM   #597
Poynton... cheers
Old 7th February 2006, 06:57 PM   #598
avr300 is offline avr300  Denmark
avr300's Avatar
Have been doing a few things. I have the one 63 as ref. and the other as mod. platform. And a 63SE as second ref.
I did the clock hack first. http://www.acoustica.org.uk/t/63/63hacks.html. Didn't impress me. The sound became "nicer" but less "live". I would say less music and more HiFi. More like the SE, but still less PRaT. Didn't like it, undid it again.
Then I bypassed the HDAM's (still with the 2140D sitting in) together with the DC blocking caps and removed the muting transistors. NOW it became more "live" - more PRaT. I still like what I'm hearing now.
Now I wonder, when I did the clock hack I simply re-arranged the 2 caps CD02 and CD03 and did the ground bounce hack. _AND_ I did this:
"Knock yourself out. Whilst you have the player apart, find link U200 on top of the board - this feeds +5v (at c.2mA) to the SM5872 onboard analogue output stage. Tin the link, cut it then connect the RHS next to CD15 (as you look on the player from the front panel) to your new +5V supply as added above. Now the DAC has separate analogue and digital feeds, lowering noise feedthrough."
Can anyone confirm feeding of the "analog" part of the DAC together with the clock power is a good idea?
/avr300
Old 7th February 2006, 07:36 PM   #599
I did all mine seperate. 1 reg for digital ,1 for analogue and 1 for dac clock ref.
I also used U200
Old 7th February 2006, 08:03 PM   #600
6h5c's Avatar
Originally posted by Franz G
Ray:
Franz
Hi Franz,
Thanks for the tips. I will try the passive filter with the first opamps still in place, and the secret zener mod. See how that sounds. I think I have an idea of what you mean.
The noise at the output I was talking about is present when the player is in stop mode. If you have no muting circuit installed you should be able to measure it. Could you see if it is present with your player? If not, your analog stage must be the solution !!
Ray.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
6h5c
Page generated in 0.20778 seconds (57.01% PHP - 42.99% MySQL) with 11 queries
