| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#51 | |
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#52 | |
One Seriously Addicted to Audio and Electronics
They must have ran out, because they don't offer it anymore Ray. |
#53 |
That makes me feel better
cheers I can get them through work for £25 each (OPA627 S08) and I need 4
#54 | |
www.farnell.com is a little cheaper, especially if you are satisfied with the A grade. But why do you want to use four of them? You can use a cheaper one in the filter, it's less critical. And it will make your player sound less ''Brown'', if you know what I mean. If you look in my opamp list you'll see OPA124 has good spec's also. You can also sign up with Analog's sample program and get some AD8610, for free Ray. |
#55 |
Wow. Turn your back for a minute and there's a million posts!
I got my opa627's from usacaps on ebay. Cost about $20 for 5. Dip rather than so8 though. Regarding the audiocom regs, I remember some grumbling on the forums that these were not that great....I'm no expert here, but it might be worth some investigation before spending your money. I notice tentlabs have just released some similar devices, and then there's the ALW jung superregs... Just to complicate things.
I w isH i cuold typpe bettr |
#56 |
OPA124.. mmmmm
So what you are saying is that 4X opa627 is not very good? If I buy 2 opa124 does this solder to the bottom of the browndog pcb or the top? I like the audiocom regs, they are worth the ebay prices! |
#57 | |
The OPA124 or AD8610 can be used instead of OPA627 after the DAC, and then goes on top of the adapter, that's IC1. In the filter I use OPA132, AD8510 or also AD8610, this goes on the bottom. If you look in the opamp table you can pick one that has nice specs. For the DAC low input offset voltage and low input bias current seems to work well. The more yellow the better. Ray. |
#58 |
LOL nice stock. It looks a like my stock of eproms I program for car ecu's.
I have purchased 2X OPA627AU and 2X OPA124UA from Farnell. They came to £42 ish. I thought this was ok. So with these chips I put OPA124 ontop (ic1) and the OPA627 on the bottom (ic2) I have just ordered some gold plated sockets for the pcb to fit into also |
#59 |
Nice ordering work there Brent.... and the final step will be psu bypass on the 'dogs.
#60 | |
No, i'm afraid you didn't read everything and ordered too fast. The OPA124 or AD8610 can be used INSTEAD of OPA627 after the DAC, and then goes on top of the adapter, that's IC1. In the filter I use OPA132, AD8510 or also AD8610, this goes on the bottom, so that would be IC2 on the adapter. Ray. |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| thierry67 |
| Page generated in 0.23002 seconds (60.62% PHP - 39.38% MySQL) with 11 queries |
