| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#581 | |
Magneto the Gravity Man
Not too late then! Current on the analog +5v at this point is fairly low and fairly constant, I should think. Can you measure any ac noise on the line at this point? Andy |
#582 |
The ac noise at this point measures 0.2mV pk-pk in stop and 0.3mV pk-pk in play.
My Audiocom Invisus to the DAC measures less than 0.1mV pk-pk in play or stop mode Brent |
#583 | |
Andy |
#584 |
not really, I do have the better caps fitted though
#585 | ||
One Seriously Addicted to Audio and Electronics
I didn't expect this high value. The DAC datasheet says 102dB S/N, so I guess better should be possible. I think the analog section is the problem, maybe not symmetrical enough. If there are more people that would be so kind to measure their output, to confirm this, that would be great. Quote:
Pins 17, 19, 21, 22, 24, 26 are all called "analog" supply pins, but the output signal is far from analog: it's a PWM signal. So I wouldn't connect it to the analog PSU. I used a separate regulator for these pins, and draw power from C813. Regards, Ray. |
#586 | |
I changed the 150R divider resistors (R124/125) to 1k, to give better filtering with the caps. In the CD67 they are standard 1k. I didn't think of a TL431 yet Regards, Ray. |
#587 | |
Hi Ray, The Vref does not need to be exactly 2.5v ( I think ) dut it does need to be 'clean'. These are in effect audio amps....... what effect does the psu line noise have on performance??? Cleaning it up cannot do any harm! Pins 17, 21, 22, 26 supply the output amplifiers so could be considered analog. I think the optimum solution is to power the DAC from 3 independant 5v supplies, clock, digital & analog. Well, thats my plan! The supply to the servo chip is 5v analog to pin12. VRef is taken from the feed to pin28, digital supply! Andy |
#588 |
I can honestly say seperating the 5V rails to DAC and Decoder helps the cdp no end. Everything just feels more complete.
Also I have fitted the HF upgrade components and my initial response here at work is wow! it isnt a massive improvement but its good and cheap. Everything is more controlled, better resonance on piano and the vocals are very smooth. Diana Krall The girl in the other room sounds soooo good. Roll on the RF mod.....tomorrow hehe
#589 |
So what have you replaced?? C504 with a BG? Some silver / micas Holco resistors?? why not c503? Now all you need to do is feed it +5v from a clean source not the digital 5v and feed the HF signal via screened coax dirct from the HF preamp board. Andy |
#590 | |
| Page generated in 0.24260 seconds (63.12% PHP - 36.88% MySQL) with 11 queries |
