| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#5601 | |
![]() I'll have my "cigar on holiday in Crete" face for a bit ![]() By the way, I like the valve ![]() Simon
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#5602 |
At least now we know why you turned green.
/avr300 |
#5603 |
Alright ... I made the two new regulators for the +12v/-12v ... bought some IC feet ... and got down to soldering them in the CD player.
The feet were pretty easy, the regulators ... not so easy. I checked, checked again and double checked just to be sure I understood what I was doing ... and found a little error in the -12v regulator. So I fixed that ... Hooked everything up and turned it on. No sound. Alrighty ... PANIC I took a look at the +12v regulator and saw that the input and the ouput pin were connected ... letting the full current run though it. It felt hot and smelled burned. WRONG ... Took it out and put the 7812 back in there ... back was the sound ![]() SO ... tomorrow I'll get me a new LM317 and re-try it I'll make some pictures when they're done
#5604 |
Hi guys.
I'm back again with another problem. I tried the servo reclocking as suggested by Brent (thanks for the info on that btw). Unfortunately a broken wire in my 5v regs plonked itself onto the +20v feed..... .....So I replaced the fried dac and reworked my regs. Problem is, when I connect 5v into vacant C4 hole (xtal power) and power up the tx starts buzzing. If I power up without the 5v supply connected to c4 it doesn't buzz. I have checked the regs voltage and it's defo 5v. Help! Anyone? Lee.
#5605 |
If a tx buzzes it usually because there is a short or demanding load.
It seems strange the 5v output is ok though,mmmmm can you remove the 5v reg with it still wired to the +20v. Check the 5V track to ground for resistance. Also when in circuit does the 5v reg get hot Brent |
#5606 | ||
Anyway, to my Q, which is a simple one. We have built 5 raygulators, 2 x 12V (+/-) and 3 x +5V. This Q is only for the 12V ones. I first started looking at just putting the 12V Raygulators in the original "drop-in" locations of the 7812 and 7912 (CD67SE btw), like in this pic from Ray back at Post # 1981. Then I started reading and reading and it seems like these ones are "better placed closer to the opamps". e.g. Peter's comment above and If I do this, does that mean I REMOVE the 7812 and 7912's at Q801 and Q802 and do what Rowey recommended to Aussie Simon? i.e. Quote:
#5607 |
I have some questions about the other 78xx regulators in the CD player. I know that the +12v and -12v is for the opamps.
What are the 7805 with the heatsinks for ? And is it a good idea to replace them too ? |
#5608 | |
Checked the 5v track to ground and measured around 200r. I think the reg does get hot quickly, but I haven't left it powered up long incase it blew something (else). Update: The buzzing occurs whenever I connect 5v to any part of the dac/decoder circuit. I don't think it's a problem with the regs cos I tried 3 different ones and my 5v invisus... Could the decoder be fried? Lee.
#5609 | |
The servo amps are unregulated. If you're talking about a 57 or 67, the rightmost 7805 powers the DAC, decoder/servo processor, CPU and front end. The one on the left powers the servo amps. The main problem is that there is so much running of one regulator, so replacing it with a better one will not gain you a huge amount. All these ICs 'talk' to each other via their power supply. The best gains are to be had by giving the DAC its own separate regulator. You can go further and have three powering the DAC. One for the digital section, one for the analogue section, and one for the clock buffer. This I recommend. A chap called Robert Noriega ('Bobwire') did a quick and dirty on how to add extra regulators to a CD67 though he only has one on the DAC. Bobwire's CD67 write-up Here's a neat way of using LM317 regulators but can also be applied to 7805s. Shown is the clock gate regulator (courtesy of Martin Clark's excellent website.) LM317 |
#5610 | |
Thanks. note: the Jones' performance was very nice, and on the web you can find Krall has done the same at Studio 104 from this radio.
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
| Currently Active Users Viewing This Thread: 5 (2 members and 3 guests) | |
| hejira858, Puffin |
| Page generated in 0.25625 seconds (66.56% PHP - 33.44% MySQL) with 11 queries |
