Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th January 2007, 12:49 PM   #5401
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Originally posted by YoungSC
Thanks Pete,
If I use the formula in the datasheet and apply it to the resistor values in the Super-Raygulators I get 1.25(1+1500/120) = 16.875 Vout
This is where I'm getting confused becuase there should be 12Vout.
However, if I use the resistor values in the first Raygulators then I get the following 1.25(1+1050/120) = 12.1875 Vout
This is more like it.
Now does that mean that R1 in the Super-Raygulators is incorrectly labelled 1.5k instead on 1.05k, or does the sum of my knowledge equal very little?
If the formula above works for the Super-Raygulators, and I want to get 5 Vout, then my calculations show that I want a 3:1 ratio for R1:R2. Am I better off using the lowest resistors I can find, or just go for a pair such as 300 ohm and 100 ohm?
Thanks again.
The Raygulator is the plain LM317/337 implementation as on the data sheet. The o/p voltage is the ratio of the divider resistors, +1, x 1.25V. So, say (1+ (360/120)) x 1.25 = 5V
The Super Raygulator, the resistor between o/p and adj pin has no bearing on the voltage. The voltage is the drop across the diodes + 1.25V (I believe - though not 100% sure). The other resistor is part of the gyrator.
Does this help?
Old 16th January 2007, 05:42 PM   #5402
avr300 is offline avr300  Denmark
avr300's Avatar
Correct, the LM3xx will maintain 1.25v over the resistor placed between output and adjust. And with the zeners and the diode the adjust pin is 10v + 0.7v up, hence the output will be 10.7v + 1.25v = 11.95v.
The 1k5 - 4u7 and the transistor is the gyrator,
Old 17th January 2007, 06:53 AM   #5403
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default DIYAUDIO.com Audiofest and Swapmeet - UK
Slightly Off-Topic
Pinkmouse is trying to start a UK DiyAudio.com meet etc in 2007.
Somewhere in the Midlands.
See :-
http://www.diyaudio.com/forums/show...&threadid=94337
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 17th January 2007, 07:24 AM   #5404
YoungSC is offline YoungSC  Australia
Alright, so for 5V I keep all the components the same except the Zener diodes. The LM317 will provide 1.25V, the 1N4148 will provide 0.7V, so I need to changethe 2 Zener diodes to 3V to get:
1.25 + 0.7 + 3 = 4.95V
Am I correct?
Sorry to labour the point, but I want to be sure, and I bet there are other people who will find this useful.
Old 17th January 2007, 07:30 AM   #5405
jksmurf is offline jksmurf  Hong Kong
Sorry to labour the point, but I want to be sure, and I bet there are other people who will find this useful. Thanks
Keep hammering away cobber, I'm finding this very useful.
k.
Old 17th January 2007, 09:19 AM   #5406
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: DIYAUDIO.com Audiofest and Swapmeet - UK
Originally posted by poynton
See :-
Andy
That URL is borked mate, it aint doing nothing for me!
Simon
Old 17th January 2007, 09:32 AM   #5407
adfinni is offline adfinni  United Kingdom
adfinni's Avatar
Default Re: Re: DIYAUDIO.com Audiofest and Swapmeet - UK
Simon
ditto
Old 17th January 2007, 09:51 AM   #5408
Am I correct?
Spot-on! Or you could use an LED with a forward voltage of 3.0v, if you want visual indication of the thing working. Some blue/white LEds are in this range , IIRC.
Note that with the the exact voltage you'll get out depends on the current through the diode (zeners typically have 10-30ohms resistance at c.5mA) and to a lesser extent, temperature (they drift as they warm-up) - but don't worry about it.
Old 17th January 2007, 09:58 AM   #5409
poynton's Avatar
Simon
OOOH!!!!
Anyone up for a UK diyAudio Meet?
This one works.
Andy
PS Simon.
Know any suitable venues UP NORTH ?
Old 17th January 2007, 10:17 AM   #5410
SimontY's Avatar
Default Re: Re: Re: DIYAUDIO.com Audiofest and Swapmeet - UK
OOOH!!!!
This one works.
Andy
PS Simon.
That link does indeed work, thanks Andy.
I'm not sure what a suitable venue is to be honest, I've never done any kind of meetup, except meeting Brent and hearing his kit! I will post on that thread to keep the off-topic-ness away.
Simon
Copyright ©1999-2013 diyAudio
