| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#501 |
Yes it's current and frequancy of the voltage that kills you.
240V at 50hz if across your body can make your heart try to beat @ 50 times a second etc etcThat defribulator thingy medics use to "get the heart working" actually momentarily stops the heart allowing it to get back to its own beat again. sorry ill go away now
#502 | |
Magneto the Gravity Man
Valves are easy too work with. Just remember the voltage !!! On this circuit, the main thing is to use "good quality" components after the dac, matched as close as possible. 6h5c I had something along these lines in mind for my balanced stage. Self-balancing cascode with the output taken from cathode for low-z. |
#503 | |
One Seriously Addicted to Audio and Electronics
Yep, I built the amp myself. There's some more pictures of it (and me) here. The advantage of tubes is that you need very few (passive) components to make a good working circuit. A simple common kathode circuit is stable and has enough bandwidth by itself already, and the amplification is not too high, so you don't need feedback to "fix" all that. I think feedback is a killer for the sound. Furthermore the characteristics of a tube are more friendly compared to a transistor. The same philosophy can be followed with transistors or FETs though. The high voltages require a different approach to building, but once you get the hang of it, it's very easy. It's more mechanical compared to a PCB with parts, most circuits can be hard-wired. Regards, Ray. |
#504 | |
This is starting to look like the Tubes section.... Nice circuit, didn't know that one yet. Where did you find it, or did you design it yourself? It has balanced inputs Technically you only have to buffer the output you are going to use with a kathode follower. Will save you one triode . A bit like this one. I found it here.Ray. |
#505 |
I think I got the idea from Kennedy Audio (?) on the web years ago.
I also have seen the circuit you posted. ( I try to avoid the site you suggested unless I have some time to waste - it takes such a long time to update !!! ) Andy PS I like your pictures - a study in concentration !! |
#506 |
Here's another one that uses part of the CD67 circuit.
It's in dutch: http://members.chello.nl/~p.gelderen...67/cd67out.htm Haven't had any trouble with the site yet, strange. Ray. |
#507 | |
Not how I imagined you'd look, lolYour work looks extremely well done, I bet it sounds like it too.
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#508 |
Just looked at your pics Ray.......are you sure you know what you are doing.
Only joking mate. Very impressive
#509 |
#510 | |||
![]() Just have no curls Ray. |
| Page generated in 0.20870 seconds (54.75% PHP - 45.25% MySQL) with 11 queries |
