| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#5031 |
There's a lot going on in Ray's photo, starting from the bottom...
His former opamps! The black resistors look like Holco brand, fantastic for the price. There are some poly caps too - both are in the output filter. The green blobs and grey collars are the inductors and ferrites that can just be wire for now. He took out the power resistors and capacitors for the HDAM (between the cans). The wires with tube insulators (probably Teflon tubing) are for his signal to bypass the HDAM and DC blocking caps (also removed) and go to where there is pretty much just an output impedance limiting resistor and RF (from the RCA socket) filtering cap. Without the DC blocking capacitors, the 10K resistor to ground after them isn't needed anymore, but really doesn't hurt to stay either. There are also two pairs of 100 ohm resistors R657-R660. Now without the muting, one of them on each channel can also be replaced with a wire jumper to better drive your preamp. In the parts sheet, it says to replace one with a 47 Ohm resistor, which is fine too. If you want to use existing traces, jumper R619 and R620 locations that are now vacant. |
#5032 | |
I've been following your arrival (same CD67SE as you, just a 110v version grrr) and I'm very very happy that folks like you come along and ask all the questions about things that I'd also like to know. Like you I have no knowledge of anything electronics-wise, but I like DIY and fortunately my wife does know about this stuff. There's so much going on here at such speed and with so many different combos, that sometimes you get left floundering... (btw I'm getting a 240v CD67SE Transformer from Singapore where you're based). Wife has soldered most everything on Ray's list, with just a few question marks I will post later. She says she would like to put it back together and try before we go any further (i.e. PFM Flea Clock, PSU, Vreg Boards (see below), MartinClarks Clock Hack). SimontY's confirmation that you (we) can leave those 4 red 110uf/25v Cerafines between the OPAMPs (LM4562 already in) in place above is a godsend, I was muddling what to do with those ... they are smaller, but I understand that it's OK? esp. if you put VRegs "around the Opamps"? I had no idea about what these folks were talking about when they said "move the VRegs closer to the Opamps" until a helpful fellow (Mags) on another forum pointed me in the right direction. I posted a pic of it earlier, but it got lost in the flurry of posts, so I'll post it again, hopefully we'll get a comment or 3. Please? Ray, As mentioned, I have got my Flea PCB with clock module. (I might get 2 more w/o clock later if Martin Clark does another run). Anyway my wife has soldered it all together (looks good) and it already looks the business. I remember seeing 3x Fleas in your CD63? but the photos showed the fleas alone, not the connections and I was wondering if you could: * 1st let me know the clock conection details (what to take out, extg clock + 2x caps?) just insert new clock leads in old clock spot? and * 2nd where did you connect the other 2 fleas, exactly? Thanks! k. |
#5033 | ||
#5034 | |
I did try to read but with the massive amount of terms and ideals and many parts that i do not know, i am stuck at many occasion, the guys here are really helpful, and i am somewat worried that i might irritate them with my loads of newbie questions. Once again, I would like to thank all those who contributed in one way or another. Regards, Marcus |
#5035 |
#5037 |
Hi Marcus,
Good work on the mods! Now, I could be wrong, but.... D852, which you appear to have replaced with a schottky diode, was originally a zener diode. Please someone correct me if I'm wrong, but this was the diode that adjusted the ground at the -18v reg that powers the display, making the output -24v. In mine the reg is changed to a 7812 and the diode is shorted. This makes the display voltage -12v and it's nice and dim. Simon
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#5038 |
hi simon,
oh **** i looked at the mod list wrongly, i was a little skeptical too as i notice that that it defer from the rest of the diode. I am about to power it up soon have just completed the by passing and all those stuff. What will happened, if its a wrong diode? |
#5039 | |
Then again, if you got it from Ray's list, it's fine. The man knows! Simon
#5040 |
i look at the mod list wrongly, its should be change D851/854, i look at it as replacing D851-854...
Sweating now.. hope someone can help out asap.. btw is D852 and D853 of the same diode and value..? |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Malefoda |
| Page generated in 0.27862 seconds (69.54% PHP - 30.46% MySQL) with 11 queries |
