Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 5th December 2006, 07:59 AM   #4961
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Those goldenjacks are a good price. His plugs look like the WBT types.
Brent
Old 5th December 2006, 08:10 AM   #4962
Chivvyp is offline Chivvyp  United Kingdom
Default Single op-amp
A year or so ago I had my CD63KIS modified (new clock and output stage biased to class a). When it came back it sounded better and in the meantime I'd discovered this site so I made a few changes to voltage regs diodes etc. and left it. Bought a CD67 and started from scratch.
I decided to revisit the 63 and see if there were any more improvements that I could make with the benefit of (your) experience.
When I looked at the new output stage I found that the analogue output from the dac was taken to a new board sat on top of the hdam cans bipassing the normal filter and dual op-amps completely.
On the board is a new filter, transistors (one per channel, presumably to bias to class a) and a single op-amp per channel (LM6171).
Has anyone else tried replacing the dual op-amps with a single? From a technical viewpoint what would be the supposed benefit of doing this? What are the likely downsides.
Pete
Old 5th December 2006, 08:23 AM   #4963
awpagan is offline awpagan  Australia
no opamps.
passive filter then fet or transistor buffer.
I prefer the fet version
allan.
ps and no DAMH
Indecision makes the world gone round.
Maybe
Old 5th December 2006, 08:26 AM   #4964
Chivvyp can you post some pics.
Brent
Old 5th December 2006, 08:38 AM   #4965
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: Single op-amp
Interesting.
You may be the first on this thread to have heard a 'class A' output.
Who did the mods ??
As Rowe said, can you post pictures of the top and bottom of the board and any values you can see?
Andy
Old 5th December 2006, 08:48 AM   #4966
I think this was mentioned before
http://tangentsoft.net/audio/opamp-bias.html
allan
Maybe
Old 5th December 2006, 09:24 AM   #4967
Brent
I'll try to get some photos tonight. Probably only the top as the board is soldered to the hdam cans and I don't want to remove it before I have some idea of what I'm going to do with it.
re the tangentsoft links - I just built a PPA headphone amp from them and biased the opamps in that (using a fet cascode rather than a single). To be honest I can't say that I noticed any difference before and after adding the class a bias but the basic amp was stunning and probably exceeded my hearing capability anyway.
Any comments on the general principle of using a single op-amp rather than a dual.
Pete
Old 5th December 2006, 09:53 AM   #4968
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
The LM6171 may be being used to perform differential to single-ended conversion and LPF duties (it is very well suited to this task) but then why not use half of the existing circuit? So this is unlikely unless they have a standard board they use in various players.
It may be that they took only LO/RO (or LON/RON) from the DAC (i.e., only single-ended), fed it through a passive filter and then used the op-amp as a buffer and/or to provide a bit of gain to make up for the drop in voltage of not using the differential output.
You can make an op-amp class a by attaching a resistor, CRD or cascoded JFET between the output and the supply rail with the worse (or is it better? can never remember!) PSRR.
A pic would be nice.
I've currently got the first half of the op-amp as normal, and fed to the HDAM which I've converted to be the 2nd stage of the LPF (like in the CD6000 but single-ended). So it is the same circuit as the dual op-amp in principle, though I have the Bessel filter slope. Mine's a 67SE.
I tried various combinations in A/B comparisons (leaving the 2nd half of the dual in circuit and connected to identical interconnects) and I always preferred the discrete op-amp (bass much better).
(HDAM - if you cut the feedback track you get O/P and -VE inputs and it's a fully-functional discrete op-amp - see CD6000 schematics.)
Old 6th December 2006, 08:47 AM   #4969
Brent
Well, I took some photos but the filesizes were too big to add in so I had to resize them! Hope they're viewable.
Old 6th December 2006, 08:49 AM   #4970
The analog inputs are taken from R21 - R24 which are lifted at one end to disable the normal signal route.
Pete
Marantz CD63 & CD67 mods listHide this!Advertise here!
