RCruz said:
Hi Brent
Before I upgrade with a clock, I want to replicate your modds regarding the Servo +5v psu.
Can you suggest a TX ?
Should I use an encapsulated or a nude toroid type?
Also, can you explain how you fixed the front TX (the ones almost in contact with the display pcb) on your machine ?
I believe I will get a lot more detail and attack by feeding the servo on separate tx and two sregs.
Thank you for the inspiration and guidance.
Ricardo
Better off with a fully nude tx, you get a larger VA for the same physical size and similar cost.
My front txs are sat on a pcb which is on pcb stand offs.
You will love this upgrade
Brent
Thank you Brent
Should I use 3.2VA or a 5VA can give better resuls ? They seem almost the same height.
Ricardo
RCruz said:Should I use 3.2VA or a 5VA can give better results?
Ricardo,
1) Use the bigger one if it fits.
2) To get a "u" with umlauts you can type "Alt+0+252"
Simon
Re: Increasing opamp supply voltages
I've heard of this. I think the distortion (the measured variety) drops with increased supply voltage. You could drop +/-15V regs in as the supply is +/-20V. Just make sure the caps are appropriately rated, preferably 25V.
Über
jimh0612 said:I read somewhere that increasing the supply voltage for the opamps can improve the sound
RCruz said:
Über
RCruz said:Can you suggest the best way to avoid ground loops ?
I'm not the best person to ask, but once again for anyone reading I'll point out that external transformers can cause noise and ground problems (even whilst otherwise sounding great).
I'm aware that yours are internal, so as long as you're using a main star earth and mini star earths in the extra supplies things should work well. There are some good sites about that explain how it should be done (but I can't think where I saw them).
Simon
Thanks Simon.
Hadn't thought about the caps.
Was about to fit 470uF/16v BG STD I just got from Thomo.
I've got 470u/35v Silmics removed earlier (physically a bit large) or 100u/25v Cerafines from my CD50. The Cerafines haven't had much use, but they could be a bit small (got 6 though!).
Do you think I'd be better at 12v and using the BG's?
Jim
Jim
jimh0612 said:Do you think I'd be better at 12v and using the BG's?
Why not 14 or 15v and use the BG?
I'd run 15V on a 16V cap any day, but some others wouldn't.
Simon
Yeah, I'd heard you like the smell of smoke!!
I know it's within the range, Ray usually recommends leaving headroom, but it'd be a shame not to use the BG's as Brent especially feels they are a great match for the opamps.
I might just be a wuss and use the Silmic for now.
Sorely tempted though - I'm prone to taking risks myself! Tee Hee!
I've found Blackgates run @ max voltage no problem, cheap caps would start to bulge. I have run one blackgate 16V 1000uF @ 21V (by mistake) and realised my error weeks later. I took the cap out and it measured correctly!! I was quite amazed.
With regards to opamp voltage, well I have tried 12v 15v and 18v and the difference is slight, maybe a tiny bit more dynamic (and im talking tiny) on the higher voltage. Use 15V and the 16V BG.
Brent
Brent
RCruz said:
Thank you Brent
Ricardo
Use the 5VA ;-)
Should I use a unique common ground for the new TX and the two sregs on the servo ?
Ricardo
Always try to run all grounds to one common ground point. There is a large star point on the +10V rail before the 5v reg thats ideal or some people use the rca output star.
As long as they all go to the same point you should avoid loops
Brent
Opamp voltages
15 v and BG's it is then!
Thanks for all the advice guys.
Will post when its done with comments.
The opamps are already pretty well burnt in and sound so much more detailed and smoother than the OPA2134.
I've biased them into class A but not sure I can tell much difference if I'm honest.
Jim
Jim
- Digital Source
- Marantz CD63 & CD67 mods list
