Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 8th November 2006, 10:08 AM   #4581
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Sorry but my amp DC blockign caps are gone also... even if it seems there is another DC security in.
I am looking for what voltage in the RCA? What is a normal value? When the CDP plays?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 8th November 2006, 10:12 AM   #4582
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Brent
Old 8th November 2006, 10:14 AM   #4583
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by 6h5c
paid 140 euros for it . I've been listening to it tonight, and i'm rediscovering my cd collection again!
Superb Ray, and even better for not using Neutrik Pro-fis, as I believe these are poor sounding phonos
Guys,
where to check for DC offset at the output? and how?
I believe you simply put a multimeter, set to measure DC, from the output to ground. With the cd player turned on.
Simon
ps - anyone want to buy some Neutrik Pro-fi phono plugs?
Old 8th November 2006, 11:01 AM   #4584
Originally posted by rowemeister
The black gates needed are cheap mate. 4X 470uF 16V for the opamp or discrete are roughly 16.
220uf are even cheaper.
Brent
That's not cheap.
that's B..... expensive.
I can buy 15,000uF 63V electrolytics for less than that.
I can buy 470uF 16V electrolytics for about 0.055 that's more than 72times cheaper.
I can buy higher quality electros ranging in price from 0.13 upto 0.28. That's still 14times cheaper.
regards Andrew T.
Old 8th November 2006, 11:05 AM   #4585
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally posted by AndrewT
That's not cheap.
Me too! But those are not Black Gates...
Or am I missing the point here
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 8th November 2006, 11:06 AM   #4586
Malefoda's Avatar
I've found this:
http://tangentsoft.net/audio/input-cap.html
If I find something more than 3mv I put back the caps! I'll also check at the amp...
Old 8th November 2006, 11:08 AM   #4587
poynton is offline poynton  United Kingdom
poynton's Avatar
Only the hype can justify the extraordinarily high prices of Black Gates.
Manufacturing costs must be about the same for all electrolytics.
Andy
Old 8th November 2006, 11:09 AM   #4588
SimontY's Avatar
That's not cheap.
Black Gates are expensive compared to other caps, but when considered as a valuable upgrade, like a clock or an interconnect, they offer very good value for money.
They are not a tool to get a job done, they are an upgrade over less expensive caps. The sound improvement for 25 is greater than you could get from almost anything else (apart from new op-amps or using hard cone feet, but we've already done that....)
Simon
Old 8th November 2006, 11:22 AM   #4589
SimontY's Avatar
I've found this:
3mV is nothing. Even with a gain of 25 in your amp that's 75mV at your speakers. What will that do? Very little!!
Can anyone please confirm? Don't want to dispense incorrect advice!
Si
Old 8th November 2006, 11:38 AM   #4590
ImSparticus is offline ImSparticus  United Kingdom
Malfodo, the Amp should have a coupling cap on its input in the circuit, if you are concerned you can also check the dc offset at the speaker terminals in exactly the same way, i bet you get zero !
Simon your right, probably wouldnt do anything apart from may be cause hum or coil heating, the speaker coil being bigger will tolerate it, but headphone coils are smaller and less dissipative, so be carefull with those Senheisers lol. Anyhows, i think the cd63 headphones is coupledanyhows, and if not Malfedo, what the hell is it still doing connected LOL, dump it you dont need it.
The CDP output listed at 2V is the music signal to put it simply, its the peak to peak or rms output of the music fed to the amp, not the dc offset. You would only have problems with dc offset if the amplifier was not coupled correctly at the input or the output. So just check offset at the speaker terminals to put your mind at rest, it will be fine im sure ( do use 911 orr 999 for the emergency services ?? ) lol
SIMON, how much for the neutriks, u can mail me some details if you want, subs757@msn.com.
Dennis
Marantz CD63 & CD67 mods listHide this!Advertise here!
