| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#4431 | |
How about silver mica or polystyrene caps and precision resistors around the servo and RF and HF amps? This is lined up as one of my next mods for sure. You could shield the logic and driver chips, and perhaps do some coax runs. Beyond that you really need to add some separate regs to make it super-duper, and reclock it. Simon
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#4432 | |
I would remove the head phone section if you dont listen to head phones, a nice waste of silmics otherwise. Also you need a good clock and then work on seperate regs.Thats when the player really starts to push the realms of what this player can do. Brent |
#4433 | |
Excellent Brent |
#4434 |
Mornin,
you're all feelin' I've dampen too much the CDP? Maybe I'll remove the side top plate bitumen (may help take some heat out). I think if main is a point to master that this should be one problem. At my previous flat in a big town it show 238 V all the time, and maybe once a day it show 237.8. Right now within one minute it changes from 220 to 225, and if the meter is looked for several minutes it can show from 217 (never seen less) to 232. And the winter days, time (change of one hour to change the load on powerplant) seems to be the strating point of my "downgrade" feeling... I'll have a look in the Arcam. Does my all CDP lines caps upgrade may have done harm to sound? I've put my left Elna RJH 120/16 beside the OPAmp (feeding lines) and at the HPhone socket. All are 100n PPS bypassed... Thanks Simon and Brent, and all others!
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#4435 | |
I find Blackgate are the best caps to use for the opamps. Also the 16v 220uF silmics are pretty good here. Swap one bit at a time Brent |
#4436 | |
Do keep in mind that your new house will have different mains and different earthing and a different structure. Unfortunately, these factors are more important than your actual system but they can be hard to fix. I took a downgrade the last time I moved house and even with extensive work on the room it never got quite as good. I've compensated by upgrading the system itself but the problems remain to some extent. One thing to try re. mechanical resonance: if you want a thuddier bass sound try adding something heavy to your rack and/or cd player lid. I'd normally advise against this sort of thing but it could be worth a try. Simon
#4437 |
Brent, I've just closed it, the lid has no effect, maybe better with. So no problem here.
Simon... no earth on the wall plugs here! That's why right now my socket does not link to star earth RCA point. But the amp is also not earthed... my furniture is a very heavy one with steel frame. A pain to move! For the amp:
#4438 | |
#4439 |
Hi Simon,
post3997 shows the star grounds connected back to safety earth via the wire from "psu star" to "E". I think it would be better to adopt power amplifier topology and use a disconnecting network in lieu of the wire connection. It also appears that you have both zero volt rails connected 4times to the stars (have I read that right?). There is duplication here that creates a loop that could/will pick up inductively coupled interference. After you have removed the direct connection to safety earth you can try using the "cdp star" only and removing the "psu star" and it's two connections to zero volt rails. Then connect "cdp star" to the disconnecting network then to the safety earth. The extra cost is tiny in comparison to your super-regs.
regards Andrew T. |
#4440 | |
I'll email you... Greg |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Malefoda |
| Page generated in 0.25288 seconds (67.57% PHP - 32.43% MySQL) with 11 queries |
