Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th July 2006, 10:34 PM   #3631
Nah no shorts this time I didnt touch anything except taking out the output caps and Hdam. It was playin fine and in the middle of the cd it stopped. And the laser doesnt do anything and the disk doesnt spin. I havbe a feeling the servo chip went bad or something. I probably cant even return it to the seller because of the mods I have bad luck with these players. I cant seem to find the 67 service manual any place ?
Old 28th July 2006, 10:49 PM   #3632
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Are you sure it's not the main ribbon cable? You could try making the fit of it tighter by placing a piece of electrician's tape on the non-conducting side of it and reinserting it. This was a tip I got from Poynton about 5600000 posts ago lol
Old 28th July 2006, 11:01 PM   #3633
Yeah it isnt the ribbin I tgreid wiglleing it and treid a differant one i have from my other player. It wasnt like I took it apart and then when I put it back together it just wouldnt work. It was playing fine and in the middle of a cd just died. I dont think it was anything I did. All I did was to disconnect the Hdam and outout caps. Nothing anywere near the servo was touched. I cant even find a service manual for the 67 anywere onnline? ANyone have the service manual?? I need to know what vvoltages I should have at the servo chips. Im really having bad luck lately, Im starting to think something is wrong with the power in this house. I know that the power on my block is pretty screwy, theres to many houses on the transformer, and when my neighborslarge air conditioning unit switches on all the light on the block dim, at night you can see the street lights turn off then back on when his A/C switches on!! All the lights in my house dim as well. We filed numerous complaints with the power company to no avail. But im seriously thinking the power has something to do with my equipment all dying. I just moved to this house about a year ago and Ive had three components die on me already!!! Maybe I need to invest in a better power condittioner, im just use a very basic Monster Cable AV1000 for everything except my amp which gets plugged direct to the wall socket as per Exposures recomenddation.
Old 29th July 2006, 06:51 AM   #3634
avr300 is offline avr300  Denmark
avr300's Avatar
Originally posted by SimontY
Just a normal musician's site. Has a list of his equipment, including which speaker brand he uses And a list of albums, one of which is now on my Amazon "wish list". Looks good.
He is a double-bassist.
Simon
Ohterwise try www.cdon.com They have the scandianvian artists.
Join http://TurnMeUp.org
Old 29th July 2006, 10:43 AM   #3635
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Just send me an e-mail...
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 29th July 2006, 06:52 PM   #3636
Okm I found one thing that maybe the problem. Im ionly gettin 4.9v from one og my 5v regulators q811. Could this be the problem possibly?? The transport doesnt do anything doesnt spin, ;aser doesnt do anything, and I tried two transports that I know are good with the same results. Very strange stuff. Any ideas what would cause something like this.
thanks
Franki
Old 29th July 2006, 10:11 PM   #3637
OK Im almost ready to give up messing around with these players, my cd53 descided to stop working again, I didnt even touch anything, it was working for a week fine and it just stopped and i get error o2. I check everything, all voltages look to be ok. So now i have two non working players. I think im ready to rtry something else. Im thinking since most of my music is on my hard drive anyways, maybe a usb Dac would be the best way to go, no more sled and focus errors! Im wondering if I could some how connect my computer up to the dac in my cd53?
Old 31st July 2006, 05:38 AM   #3638
JustIN8 is offline JustIN8  South Africa
Question PRaT and Mains Power Filters
Just noticing some posts a little while back (last week/23000 posts ago) that there was mention of how PRaT is affected by noise from the power mains. Would I be correct in my understanding that after the mains transformer and filtering, this noise still finds its way into the clock, DAC circuits etc? I saw the KE Balanced Isolator Source that Ray refered to on post 1248 and was wondering if anyone had used anything else. I was thinking of using a good quality desktop pc UPS to filter the mains and prevent other things like surges and spikes etc which could damage the input circuitry. I have not tried this option but imagine it would help the KI63 with PRaT and its general health.
I would also wonder whether one would still get the earth loop causing hum amongst two or more devices on the same circuit provider (mains earth). I see one of the latest marantz cd players does not have the earth pin in the IEC plug. Is this to remove the possible earth loop and hence impact on sound quality?
Many thanks
Justin
Old 31st July 2006, 08:58 AM   #3639
SimontY's Avatar
Justin,
Most CD players don't have the earth pin, which is to avoid the earth loop hum, as you said.
I use an isolation transformer. Big improvement I found, but not to PRAT. It seemed to make the sound more fluid and coherent, and less grainy.
I doubt a UPS is the ultimate way to go, but I'll let the more experienced have their say! Maybe Imperfectcircle could use one to stop his CD players from dying though
Simon
Old 31st July 2006, 09:59 AM   #3640
disco is offline disco  Netherlands
disco's Avatar
Default Re: PRaT and Mains Power Filters
Sorry, PRat is depending on the ability of the PSU to maintain the voltage and deliver current fast. The common mode filter I suggested is used (a.o.) to get rid of 100Hz hum and helps to keep the supply capacitors (before reg) low, presenting a lower load to the small transformer, enabling it to better maintain the voltage at changing demands. Placing the reg as close as possible to your opamps is beneficial. In that case there's only need for a small cap behind the reg to cancel some reg born noise (47uF could be sufficient, experiment with values).
Yes, via the voltage rails (after reg).
I can't think of one reason to use a switched PSU for hifi, unless currents are getting real large.
Ground on one device might be at a higher or lower level (voltage) than in another device. If the ground connection of your CDP RCA is several volts below the RCA of your amp, there's a current running through your cable, interfering with the audio signal. A solution might be (not always true, depending on the grounding technique used in the device) to connect all housings with a wire, eliminating potential differences between cabinets.
Regards, Jaap
jaap
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.21273 seconds (58.74% PHP - 41.26% MySQL) with 11 queries
