| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#3491 | |
![]() Brent reported success with new PSUs long ago, of course. Indeed bass gets more tight, less grain etc. I did experiment with shielding (on the original XO) and could hear some improvement to detail, although faint. What's you PSU setup right now? I had good results with a double L filter (common mode rejection) and no more than 1.000uF caps. So, a C-LL-C setup. Regards, Jaap
jaap |
#3492 |
I have 1000u before the regs and 470u after - and 220u locally at the opamps.
#3493 |
Hi folks, good to see people taking their players forward in various ways...
I felt due to how good my cdp is now attention was needed elsewhere, particularly in replacing my Chord Silver Siren i/c (CD>pre-amp). I never really liked this silver plated i/c - sounded false and bright and confused. So I made one with Vampire OFC copper phonos (with direct gold plate)(£10 each ) and 0.71mm DCT* (please, no commments on audibility!) enamelled copper. The conductors are wrapped in cotton and the solder was Chimera Labs (with copper content).The sound, so far, is superb! I don't know if it's getting rid of the teflon insulation, removing the silver from the wire, the good plugs, solder or geometry but it's good. A layer of white sheen has gone and the music is bold and natural. One step closer to live. It's "burning in" now of course ![]() Simon *Deep Cyrogenically Treated
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#3494 |
Is that ok to fit on the AD8620?
http://fr.farnell.com/jsp/endecaSear...SKU=567450&N=0
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#3495 | ||
Place 1.000uF right after the Schottky's. Take for both 12V rails two low resistance 20-40mH inductors (one in the rail and one in the ground), suited for at least 150mA. Again 1.000uF (for each rail). Take away the 470uF after the regulators and experiment with the value of the bypass caps. Panasonics are OK, Rubycon too. Experiment with a PPS bypass on the bypass caps (0.1 to 3uF). Jaap
jaap |
#3496 | |
Hope I don't sound like an old school professor (I did a lot of reading on the subject of audio electronics), ahum. Electrons travel most at the outside of a conductor, known as the skin effect. Each layer to cross (oxide, other conductors, foreign metals) interacts on their relative speed and introduces unwanted effects. Capacitance from isolation has a bad influance too. Optimal results are obtained from very thin solid conductors, isolated with a low capacitive layer like teflon, silk, cotton, paper etc. Personally I don't use isolation unless necessary. Flattened 0.25mm silver in teflon tube is my favourite as the tubing is quite strong. Regards, Jaap
jaap |
#3497 | |
You don't wan't caps after the reg? Only local bypass? I have 10u FC I can place instead of the 470u just for stability. |
#3498 | |
Be aware ultra low ESR brings instability for most three legs. For fast transcient response you might try bypassing the reg with solid Tantalum (20-30uF) but some reported extra noise... Have a try.
jaap |
#3499 | |
I can believe it, lol. Well what you say seems to correlate with this experience I've had. But I did try thin solid silver once and it sounded very bright and harsh and thin... I'll try again one day. Simon
#3500 | |
From your reports I know you as an experienced audio enthusiast. Still I'd like to add one remark, you'll probably be familiar with. The cable itself does not make music, of course. But: the effect of capacitance may vary from slight high roll off to subjective low emphasis. If one is 'in need' of loud lows, one might favor the 'sound' of the lesser cable. Jaap
jaap |
