Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th July 2006, 07:42 PM   #3451
Fidelity Audio's Avatar
Originally posted by imperfectcircle
I have a spare tranny from a cd63se would this be an upgrade over the one in my cd53??
The fuses are replacement stock size 1.6amp 125v. The tranny runs hot but not so hot I can touch it or anything like that. The player sounds awesome so u doubt anything severe is wrong, it could just be the hot weather weve been having its been in the mid 90's all week, even my Exposure XV integrated which is a very cool running class B design has been getting pretty hot.
Drop that 63SE tranny in. The SE tranny was upgraded to a larger Va and used oxygen copper windings. The tx is an important upgrade (just look at the KI).
Brent
Old 17th July 2006, 09:01 PM   #3452
disco is offline disco  Netherlands
disco's Avatar
Ive been thinking of an outboard supply for the analogue stage. Is there big gains to be had with this mod? Does running the opamps at 15v offer a performance advantaGEover 12V? About what size transformer would I want, would a small 20va be sufficeint?
thanks
Frank
Frank,
If you feel going outboard is advantageous, go ahead. It can be fitted inside as demonstrated here a few times. The opamp specs dictate supply limits. To be on the safe side (you might want to exchange opamps) I'd stick to +/-12V.
15-0-15@500mA makes 15VA and already is an overkill
dual power supply
What do you think of something like this for the opamp supply?? he sells the pcbs for about $35. It looks liek a pretty nice design with jung super regs?? Id prefer to use a proven design and buy the pcb then try and design my own from scratch. Any other pcbs or kits for a dual regulated supply?
Well, I don't own stocks of Audicom but one +12 and one -12V superreg is less expensive than this $35 board only.
The snubbing technique interacts on the transformer properties to cancel ringing. I don't get it how one could implement this without knowing the exact properties as they vary widely.
It seems the Swedish board does not support negative rails?
That's what I think of it
Regards, Jaap
jaap
Old 17th July 2006, 09:22 PM   #3453
disco's Avatar
Originally posted by Malefoda
Hi fellows,
here is what I get from some gentle workmates...
Got also more AD8620 ( friends want some ) and a ferrite for flat cables ( usefull for the player ? ).
I wanna know where to use the dampen material, first to load the mecanism ? And then the bottom of the case ?
Also I am now quite scared if I do the Ray's mods list my tranny will suffer... I own a simple CD53... is it dangerous ?
This black stuf, is it heavy? The idea behind damping the case is to add mass to lower its resonant frequency. Screwing in a (wooden) brace from side to side would probably do more for the thin case. Or a giant size camembert... you could fine tune it by nibbling it somewhat
The higher load presented by the bigger caps won't harm the tranny. BUT. Heating electronics over 50 degrees Celsius is disadvantageous for its trouble free operation and parts wear out faster. Your CDP will probably comfy duck this temp but it's better to be on the safe side.
jaap
Old 17th July 2006, 09:39 PM   #3454
Malefoda's Avatar
Send a message via MSN to Malefoda
This material is quite heavy (not as gold...), and it is used on some expensive machines in order to avoid vibrations and noise... my workmates stick it in the inner side of the hoods.
Machines such as this one :
http://www.datacard.com/products/pro...778245YuR3ckg6
I red in french forums that the best is the bitumen pads from under the classic bathes, as the sounds like bells if not fitted under and you can have cheap prices for some at your local dealer
I've planned to tight the case around the tranny as the SE, and maybe as you said screw a heavy iron or steel plate under. I'll manage some holes on the back panel for air cooling, something like the 67 series.
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 17th July 2006, 09:55 PM   #3455
That vibration material looks identical to the stuff I use.
Oak is good for resonance
Brent
Old 17th July 2006, 10:02 PM   #3456
Malefoda's Avatar
My furniture is oak colored, is it enough ?
Old 17th July 2006, 10:08 PM   #3457
disco's Avatar
It's self adhesive, that makes it easy to apply to odd places like corners or bent surfaces (underneath the transport).
If you're a skilled mechanic (I'm not unfortunately) you could think of a new hood for the CDP. One that features a chimney to get rid of heat the natural way. Would be original.
jaap
Old 17th July 2006, 10:33 PM   #3458
LOL yeah
Also use an airdryer to soften and bend the black stuff
Brent
Old 18th July 2006, 03:59 AM   #3459
Audiocom "superregs" are $75 a piece here in the US, and audiocom wont sell the ebay regs to the US I asked already
I can get these "discrete regulators" from Burson audio for about $18 each.
burson regulator
Or there complete power supply for about $85
buron ps-1
And theres a bunch of others Ive seen online at various DIY sites.
AudioDIYlab
shunt regulator
Old 18th July 2006, 04:00 AM   #3460
It looks identical. Ru sure its a diffsrant tranny?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Malefoda
Page generated in 0.23469 seconds (61.25% PHP - 38.75% MySQL) with 11 queries
