| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#3441 | |
No it is wrong, start looking for why too much current is being dragged from the tx, they should run luke warm and thats it. You dont want to fry your tx so take care and dont leave it on too long until you find out whats causing it. Brent |
#3442 |
On a lighter note I purchased a Russ Andrews Torlyte isolation platform off ebay.
All I can say is WOW. So much stereo seperation and detail right from the instance I slid it under my cd player. This is a recommended item. http://www.russandrews.com/product.a...MOKKUKRLFWOVXD Brent |
#3443 |
I am messing with some regs on a CD63SE and I am happy with the result.
I purchased some smt 7805 (LM78L05ACM/NOPB) and am running these with nothing other than 4x 220uF FC for the dac and decoder. I am finding the audio to be better than with T0220 packge ones, better seperation and timing. Brent |
#3444 | ||
The PSU has to deliver fast peaks to make your CDP sound 'fast'. In the plain CD63 the 12V PSU is quite poor. Building a beafier PSU for your opamps with a new (15-0-15@500mA) tranny, 8x Schottky's, 2x 1000uF, low drop regs and two 220uF BG's will improve reproduction. Note: 10 times more power than needed! Quote:
Brent is right, your CDP might suffer from an electrical problem. What fuses are in now?
jaap |
#3445 | |
![]() There's only a few mA to deliver, why not. Did you put -like before- 20cm cords between your PSU and the load? Regards, Jaap
jaap |
#3446 | |
I have tried each voltage rail individually and (no real suprise) the DAC analogue rail gave the biggest improvement. Brent |
#3447 | |
The fuses are replacement stock size 1.6amp 125v. The tranny runs hot but not so hot I can touch it or anything like that. The player sounds awesome so u doubt anything severe is wrong, it could just be the hot weather weve been having its been in the mid 90's all week, even my Exposure XV integrated which is a very cool running class B design has been getting pretty hot. |
#3448 |
Ive been thinking of an outboard supply for the analogue stage. Is there big gains to be had with this mod? Does running the opamps at 15v offer a performance advantaGEover 12V? About what size transformer would I want, would a small 20va be sufficeint?
thanks Frank |
#3449 |
dual power supply
What do you think of something like this for the opamp supply?? he sells the pcbs for about $35. It looks liek a pretty nice design with jung super regs?? Id prefer to use a proven design and buy the pcb then try and design my own from scratch. Any other pcbs or kits for a dual regulated supply? |
#3450 |
Hi fellows,
here is what I get from some gentle workmates... ![]() Got also more AD8620 ( friends want some ) and a ferrite for flat cables ( usefull for the player ? ).I wanna know where to use the dampen material, first to load the mecanism ? And then the bottom of the case ? Also I am now quite scared if I do the Ray's mods list my tranny will suffer... I own a simple CD53... is it dangerous ?
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
| Currently Active Users Viewing This Thread: 5 (2 members and 3 guests) | |
| hejira858, Puffin |
| Page generated in 0.20722 seconds (57.27% PHP - 42.73% MySQL) with 11 queries |
