| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Thread Tools |
#3431 | |
jaap |
#3432 |
Ok r127 was bad and reading 550ohms instead of 4.7, so i swaped it with a new 4.7ohm resistor and the laser is no longer going crazy. But im still only gettiing around 6.7v instead of 10v at r127? And now the disk just spinns real fast?? Any ideas??
#3433 | |
If so, something inside the Q105 circuit is drawing too much current. Could be a capacitor gone bad because of the short. If your 10V rail is low, there is another problem elsewhere. Check all caps hanging on the 10V rail, including the big reservoirs. Check for uncommon heat in ICs and 0.25W resistors.
jaap |
#3434 |
Ok replaced the caps and resistors around q105 and I know have correct +-10v. But there is still a problem, the disk tray shoots out and will not go back in and the disk motor just spins. Iwhatr does the -18 regulator control? because its voltages dont seem correct either. I get something like -6v and -24v on the input and out put. very strange stuff ehre. Any one here in NY that can take a look at it???r
#3435 |
I FIXED IT!!! WOOOHOOO!! Shoot now I hope i dont win that one im bidding on ebay!
This is the first time ive been able to troubleshoot and actually fix something using the schematic. I tracked it down to two bad feed resistors they were reading 500m ohms or something crazy like that. i replaced them and its working fine now!!! Words cant describbe how happy I am right now, what a good fweeling it is to fix something yourself!! Thanks to everyone who helped me!! |
#3436 | |
Regards, Jaap
jaap |
#3437 |
Yup I definitly learned a thing or two
First lesson dont give up so fast when your cd player dies I just installed the regulator board for the dac/decoder and the player is sounding real nice. One thing I notice about this player is that it had plenty of detail but is still smooth sounding it does lack a bit in the speed and timing department though, maybe when i add an upgraded clock it will take care of this?
#3438 | |
A superclock with its own psu will bring up the best from this player. You'll love it! Further mods can be a starground and shielding of the RF lines. The effect will be somewhat less obvious: blackness of background, tranquillity of reproduction and more subtile highs. Very worthwile but it needs some skill to implement.
jaap |
#3439 |
So you think maybe the 1000uf/16v caps for the opamps are slowing down the sound? Maybe ill go back to the 100uf -220uf caps. Ill have to order some I dont have any of that size left, maybe ill got with some blackgates there
#3440 |
Ive also notices the power tranny runs very hot, i dont know if it did before the mods or not?? is it normal?
| Thread Tools | |
| Page generated in 0.18400908 seconds (65.21% PHP - 34.79% MySQL) with 11 queries |
