| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#3411 | |
Power supplies make great mods for analog and digital consumers. I had good results designing PSUs with low capacitance to maintain both minimal load currents and fast recovery. Take only the best available and try to keep internal resistance minimal. Short connections are beneficial but sometimes unpractical. For this reason and for seperating different consumers you need decoupling caps. Start with a low value (10uF) as currents might be modest and increase to a point there's no more audible gain. Best results are obtained when you use decoupling caps in ratio to the current. To find the optimum one has to measure every individual consumer current for a PSU Regards, Jaap
jaap |
#3412 | |
If anyone has a spare main board or whole cd53/63 they want to sell let me know.
So no good deals for me. That stinks I was going to buy a bunch of the super regulators at the ebay price. Im going to look into those Burson Audio guys they have discrete super regs for around $18USD each on ebay, Ill give them a try when i get another cd63 to mod.You could also try one of those $30 clocks from these guys, i want to try one and see how it is, but I cant now untiol I get a new cd53. inexpensive clock upgrade |
#3413 |
Just wanted to add that before my player died I got to listen to a few cd's and I must say it was sounding really amazing and wasnt even broken in yet. Heres a list of what I had done
Power Supply: -c803/804 2200/35 Pana FC+.1uf film -c806/806 1500/16 Pana FC+.1uf -c813 4700/16 FC+1uf -c814 3300/16v FC+.1uf -c815 4700/6.3 FC+.1uf -D801-804 11dq10 Schottky -D811-814 11dq10 Schottky -Choke + .47uf X2 cap on AC input -Chokes+feritte beads on all power feed resistors Analogue Stage: -Opamp AD827 + 4x1000uf FC+.1uf wima -all caps in filter stage are 1% polystyrene -all resistors are .1% Dale RN55 -removed muting transistors -removed output caps Digital section: -"Clock Hack" -.1uf smd XR7 caps on power pins of Dac/Decoder all decoupling caps replaced with Rubycon ZL/ZA+.1uf smd XR7 Mechanical: -damped transport and chassis with bitumen -bottom plate sandwhich of two sheets of aluminum plate(1/8in) with foam damping sheet in between -adjustable cone feet So I guess Im going to have to pull all the parts and start over when I get a new cd63. I cant wait to hear what it sounds like with a good clock, the regulator mod and some super regulators for the opamps!!! Hopefully my next attemp will work out better than this one! than you guys for all the help you have given me. |
#3414 | |
You've put beads on the 4.7 ohm / 0.25W resistors. Make shure they are isolated from the ground plane. If not causing the trouble, next: Remove the 4.7/0.25 resistors one by one to isolate the short. Go from there for repairs. Jaap
jaap |
#3415 | |
U192 is factory replaced with a res. 390R It's the same my CD53 and in my 63SE. I'll lift the 1M and RD14/C521 and connect my Flea to this point. Am I overlooking something here (just before I'll start soldering).
/avr300 |
#3416 |
Well, without the 1M between pin 13 and 14 and the C523 from pin 14 to gnd, it won't spin. So there IS an incorrect between the schematics and the "real world" - because the schematics won't run!
So, is the decoder sensetive to jitter and do the DAC clk out introduce jitter - in other words, is it worth getting the direct clock from my Flea to drive the decoder or should one stick with the factory solution.
/avr300 |
#3417 |
The board layout in the manual corresponds to the schematics, pin 14 is NC - but not to the board in my hand.
/avr300 |
#3418 | |||
Jaap
jaap |
#3419 |
Yes, have seen it, but I just don't get why it won't run without the components leading to pin14 which is output
![]() 1M + C523 to gnd - then it's happy. Not else. Well never mind.
/avr300 |
#3420 | |
Before it started blowing fuses i got erro message 12 which is a sled error any ideas what would cause this?? I treid a differant transport and got the same result. thanks Frank |
| Page generated in 0.21930 seconds (59.14% PHP - 40.86% MySQL) with 11 queries |
