| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#3331 | |
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#3332 |
I just received my new cd53 that i bought on ebay for $30 and its working great. So now the real fun begins. I am starting friom scracth with this player and im making a parts list so i can place orders. Im planning on using Oscons for all the smaller caps in the digital sections and Silmics for the analogue stage. But for the larger main power supply caps im not really sure which caps to use, Panny FC, Rubycon ZA, Blackgate, Silmic, Stargets....etc Whats everyones opinions.
thanks Frank |
#3333 |
Well for me Black gates everytime, but they are alot more expensive.
I use pana FC in other players I mod with a plastic cap across the underside. This works a treat Brent |
#3334 |
Where do I buy a new CDM12.1 at cheapest ?
Grandata, http://www.grandata.co.uk/acatalog/G...UMBER_676.html has it at £16 + £5PP but do I find it cheaper elsewhere? Some total i.... has tried in the past to fix my "new" CD53 and has ruined the ribbon leading to the laser hence focus error now. ![]() Anyone of you guys have a working spare you could - ehhh - spare
/avr300 |
#3335 | |
Can you not run some thin wire to the points were the cable connects. It should be easy enough. Also try these http://www.dalbani.co.uk/electronic_...ckups.php?p=5| Brent |
#3336 |
Can anyone tell me if besides the resistors in the output filter, are there any others that are in the analogue signal path that may benefit from a better quality resistor?? There looks like thier might be a few right before the rca jacks r657-66, r651,r652, rn15-18 are the ones im talking about.
Frank |
#3337 | |
Brent |
#3338 |
Thanks Rowemeister!! So the only resistors in the signal path are these??
R601...604 R607/608 R609/610 R605/606/611/612 RD21...28 I will be using Dale cmf55 .1% resistors in these spots since i already have them on hand. But im thinking if they are in the signal path maybe a better resistor is a good idea?? Maybe even going high end with Vishay s102, expensive though!! Maybe I could get some free samples. Most companies are pretty cool about small quanities of samples. |
#3339 |
On to more important things. My opamps and adapters arrived today. Im using a combo of opa134 and opa627 both are "dip" style and im using browndog adapter. This is the first mod ill be doing to the new cd53 i picked up the other day. Now a few questions.
Ive read that I should put a small cap across the power pins from + to -?? Do I do this on each individual opamp or just on the adapter. Also should i put a cap from + to ground and - to ground?? What kind of caps would I want to use here?? I have some 33uf Oscons, would they work well or do I need a smaller film type?? I cant wait to get these babys installed, im hoping for a nice upgrade going from the stock opamps to a opa627! Thanks |
#3340 | |
Brent |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| mikvous, hejira858, Puffin |
| Page generated in 0.20907 seconds (57.94% PHP - 42.06% MySQL) with 11 queries |
