Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th January 2006, 12:21 PM   #311
Michi124's Avatar
What size is the toroid in the KI-version
- and what is the max. size that fits in the chassis?
Brutalized by bass
and terrorized by treble...
Old 17th January 2006, 12:24 PM   #312
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by avr300
I'll just fire up my Weller.
Especially good if the slowness can be cured. Can anyone pinpoint the slowness - or even better, the cure for it?
Altho it's already been addressed, I'd say these things will cure this colouration lot:
- clock (only with good psu) [improves PRAT and solidity a lot]
- hdam bypass [speeds things up, and it's just sublime]
- dc block cap shorting [the bass becomes more free etc.]
As for the 'information' - do most of the things discussed in this thread (yes, it's a lot of work) and you'll be surprised at just how much information there is on CD (I was!).
For the tonal balance/colour etc. I would suggest that's largely down to resistor choices, the op-amps used and their psu bypass caps (perhaps!).
Old 17th January 2006, 12:26 PM   #313
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
If I estimate from the KI picture I have, I would say 7cm. maximum.
That would correspond to about 30VA max. I think it can be done.
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 17th January 2006, 12:37 PM   #314
Fidelity Audio's Avatar
Here is a pic of KI TX
Old 17th January 2006, 12:41 PM   #315
6h5c's Avatar
Thanks dude, that's better. Mine was a bit small
How big is that thing?
Now, would you be so kind to unsolder some wires and do a current measurement on some of them?
Ray.
Old 17th January 2006, 12:44 PM   #316
SimontY's Avatar
Uh, humm, looks like someone got a bit excited with his regulator boards and dumped his salty lassi in the player...
(see mains filter cap above power switch)
Old 17th January 2006, 12:46 PM   #317
Lol you mean jizz hehe
The TX is 7cm in diameter. Good guess
Old 17th January 2006, 12:59 PM   #318
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Hi.
I've just looked at Antrims site.
The 50va has the following dimensions :
Power rating 50VA
Regulation 13%
Dimensions: 81 x 38mm
Weight: 0.8kg
Would that fit??
(My 63 is not accessible at the moment!)
Andy
Old 17th January 2006, 01:02 PM   #319
It will be very very tight against C803/C804.
Will it mount the same?
Old 17th January 2006, 01:02 PM   #320
poynton's Avatar
ps
80va is only a little larger
Power rating 80VA
Regulation 12%
Dimensions: 90 x 35mm
Weight: 1kg
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.20872 seconds (64.20% PHP - 35.80% MySQL) with 11 queries
