Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th January 2006, 11:29 AM   #301
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Nothing to add to the above....
The 'slower' playing that you mention is a typical Marantz thing. It will be gone after you mod the player.
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 17th January 2006, 11:31 AM   #302
avr300 is offline avr300  Denmark
avr300's Avatar
I'll just fire up my Weller.
Especially good if the slowness can be cured. Can anyone pinpoint the slowness - or even better, the cure for it?
Old 17th January 2006, 11:37 AM   #303
Fidelity Audio's Avatar
Op amps, Hdam bypass and output caps removed is a good start.
Also a nice clock
Just for starters of course
Old 17th January 2006, 11:37 AM   #304
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Yes, I've got one of those. Great - you can solder everything in one go!
Old 17th January 2006, 11:38 AM   #305
poynton's Avatar
Originally posted by Biskit
Also I've replaced the ribbon cable from the transport to the main PCB.
What did you replace it with???
Any photos?
Andy
Old 17th January 2006, 11:57 AM   #306
6h5c's Avatar
If you read the TNT article you will find a little jitter experiment on the first page. It seems to be jitter that is responsible for the slow, smooth sound. So I guess an external clock with a clean power supply will do the trick here, as well as better PSU arrangements around the DAC.
Ray.
Old 17th January 2006, 12:00 PM   #307
Michi124's Avatar
Hi everyone,
an extremely educating thread, thanks a lot.
I'll order parts right now to cure my CD-67
One suggestion:
When spending so much time AND money to get the best out of these machines,
I see no reason NOT to go for a dedicated custom-made transformer
Originally posted by poynton
The display section was the reason I kept the Marantz transformer - sourcing a 'better' custom one would be expensive!
A custom-made toroid is not that expensive when you order, say, ten of them.
I participated in the group buy for the Pedja Rogic DAC's toroid (made by Antrim)
and worst thing were the shipping charges for those heavy beasts.
Trannies for the Marantz won't be that heavy.
However, with the experience of this groupbuy I tend to say that having toroids
manufactured in Germany and then shipped to the buyers will give significantly
lower prices for everyone - including you in the UK.
This is because of:
- slightly lower prices from the manufacturer
- lower german VAT
- *much* lower shipping
Which voltages and VA-ratings would be needed in addition to those of the standard trannie?
If we can agree on one type of toroid I'd volunteer to ask for some quotes...
Brutalized by bass
and terrorized by treble...
Old 17th January 2006, 12:04 PM   #308
6h5c's Avatar
Hey, i'm in! For two pcs. at least!
Aside from the present voltages there should be maybe three? extra 9VAC windings for separate powering of the DAC and clock. Could a 30VA be enough?
Ray.
Old 17th January 2006, 12:06 PM   #309
True and a good idea.But isnt the KI toroidal tx a custom made one anyway?
Its supposed to be a custom oxygen free copper winding jobby.
For CD63 and SE I fully agree
Old 17th January 2006, 12:18 PM   #310
6h5c's Avatar
For a KI it would be more sensible to use the original tranny and add a small one for separate supplies. But for the 63/67/SE/OSE it can be the same tranny.
We will need at least:
3x 9V for clock and DAC supplies??
1x 3,5V for display heaters
2x 9,6VCT for internal 5V and +/- 10V for drivers
2x 17,6VCT for +/-12V for opamps
1x 13,6V for display Vftd
These values are from the 63 schematics and the 67 will also run on that. Since most of the voltages are regulated, they can be rounded off to nice values.
Ray.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.20462 seconds (58.30% PHP - 41.70% MySQL) with 11 queries
