Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 19th June 2014, 07:45 AM   #20361
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Yes, it's different for the CD63, that's why it says 'CD57/67 series' ;-)
For the CD53/63 series you need to:
- remove U116, U124 and DF52 to isolate the RC-5 signal
- remove RF52, RF54 and RF61 to disable the 5V power supply for this circuit
- insert a jumper wire from U116 (the hole farthest from QF61) to U124 (the hole near U121)
You should have a working remote after this, if not, then something else is wrong.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 20th June 2014, 12:58 PM   #20362
higlander is offline higlander  United Kingdom
In my post #20358 I mentioned that I will replace the stock TX of the CD63 with 3 coroidal TXs:
The 3 TXs have eventually come and I have now completed the modding project for my friend. It works wonderfully well as expected. No issues at all. My friend is really happy with it. The total cost inclusive of parts and the CD63SE is about 300 (of course excluding my labor cost ) I think in total I have spent about 2-3 days to complete the job.
Old 20th June 2014, 08:40 PM   #20363
lymmlad is offline lymmlad  England
Nice job, Higlander!
Old 21st June 2014, 06:02 PM   #20364
dnic77 is offline dnic77  United Kingdom
Thank you very much ray, the remote is working again! I didn't realise how much I've missed a simple device.
Thanks again ray.
Dave.
Old 24th June 2014, 06:12 PM   #20365
6h5c's Avatar
Great, glad to hear it's working again!
Old 25th June 2014, 08:38 PM   #20366
Has anyone (UV101?) set up a separate tx to power the laser and motor drive? I believe this will require 6 regulators! So it's not going to be cheap.
If anyone has done so, what difference did it make? I know when I set up a sep tx and power supply for the servo it made a big difference. I have also set up separate txs and power supplies for the output stage (with HDAM bypass), DAC digital, DAC analogue, decoder (big difference!), the servo clock and DAC clock. I am currently in the process of setting up Ray's DOS board.
So what I'd like to know is whether the cost to power the laser and motor drive will be worth the SQ improvement. Thanks in advance.
Old 26th June 2014, 09:59 AM   #20367
pjoliver182 is offline pjoliver182  United Kingdom
Default CD67OSE Upgrades - Issues on 1st power up
Hi folks, I'm in need of some troubleshooting help:
I've just finished modding a CD67OSE using Ray's pdf instructions (the CD57 version though). I have not made any modifications to the analogue sections or clock yet.
On power up the player displays "Disc". I press eject and the tray opens. I insert a CD and press eject and the tray closes. BUT the turntable motor makes no attempt to turn and read the CD and so "Disc" remains on the display. I have seen that the laser is working so I was wondering if the problem was with the servo drivers and/or the micro controller.
I have checked the polarity of the electrolytics I've installed in those sections and everything seems to be okay.
I will try putting the player in to service mode tonight to see if that points me to the problem part of the circuit.
Anyone else experienced this before? or might know which part of the player I may have made a mistake on?
I deviated from Ray's instructions in one area - I ran out of ferrite beads and so the inductor installed at RY11 has no beads - could this be an issue?
Old 26th June 2014, 10:24 AM   #20368
timjar is offline timjar  England
I modded a cd67 15 or 16 years ago(Thorsten Loesch) , I had the same thing, discovered if I powered the unit off then back on quite quickly it would work, occasionally it took two attempts, my own theory is the larger capacity capacitors are consuming the power when you first switch on(but then I know very little).
I still use the player in it's original modded form but may get around to addressing the problem when I have finished modding a cd63.
Old 26th June 2014, 01:46 PM   #20369
Looking through the forum, I guess the first thing to do tonight is to try the service mode for error codes and check the voltages at the regulators and each individual chip
Old 26th June 2014, 02:26 PM   #20370
Alwaysfixing is offline Alwaysfixing  United States
I just found this thread, I purchased a Marantz CD 63, I was surprised to find
when I opened it up that all the Caps are Elna Silmic's in it (redone?) the problem
is that it has is a balance issue sound seems to go to the left of center, can it be
as simple as the input rca's or another problem??
Al
Marantz CD63 & CD67 mods listHide this!Advertise here!
