Marantz CD63 & CD67 mods list - Page 1976 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th September 2013, 06:40 AM   #19751
bikeral10's Avatar
Default re laser
Originally Posted by higlander View Post
Why changed servo ICs and not the Laser unit ?
Tried lasers from known good players and still error 02 laser focuses but no drive on motor.
cheers alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 13th September 2013, 07:04 AM   #19752
cheers alan
Try to adjust the distance of the laser head and the CD disc by slightly adjusting the position of the rotor in the motor spindle. It will solve the issue in many similar occasions that I had encountered in the past.
Old 16th September 2013, 07:23 AM   #19753
bikeral10's Avatar
Has anyone tried altering the filter im sure i read that fitting a couple of styroflex 470pf @ c605/6 made a nice difference? any thoughts.
cheers guys alan
Old 16th September 2013, 06:02 PM   #19754
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Hi Alan,
I tried that a few times, maybe you've read it here?
470pF will get you close enough. The filter gets a more smooth roll-off and you can hear the difference in the high-end. If the player is not fully tweaked and still sounds a bit harsh, it can be a good tweak to make it sound a bit more friendly. But after my player was decently tweaked, I went back to the original filter to have a bit more 'bite' and detail in the high-end. That was before the DOS entered the room. The passive filter of the DOS can also be changed to Bessel by the way.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 16th September 2013, 06:48 PM   #19755
bikeral10's Avatar
Default thx ray
Originally Posted by 6h5c View Post
Hi Alan,
Ray
Yes thats where i saw it, My players quite well tuned clocks recap no dos as yet servo psu opamps many regs so on the way.
thx ray alan
Old 16th September 2013, 07:19 PM   #19756
thx ray alan
I am using 330pF and it makes the sound a little bit more smooth. I have read someone used 220pF but its effect is not that noticeable and 470pF will make the HF roll off by a bit too much.
Old 19th September 2013, 12:55 AM   #19757
barry.childs's Avatar
Now that we know the philips chinese lasers are crap, what about adapting the circuit so that we can fit a sony laser!
Old 19th September 2013, 07:30 PM   #19758
bikeral10's Avatar
Default re 470uf
Hi Alan,
Ray
Tried it had some caps from a german company. Bit too lack luster 470 pf a bit to much,Next may try a dos or valve output have a 6n2 output stage may have go at.
cheers guys alan
Old 19th September 2013, 08:41 PM   #19759
6h5c's Avatar
Did you adjust R611/612? You should, this gets the roll-off frequency back to where it should be.
Otherwise, I can recommend the 220pF capacitor between the 10k resistors. This is a very nice tweak to get rid of some 'digitalis'.
Ray
Old 20th September 2013, 09:00 PM   #19760
bikeral10's Avatar
Default re values
Ray
What value did you use ray?@r611/12,
many thanks alan
Copyright 1999-2017 diyAudio
