Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 6th April 2013, 07:32 PM   #19201
luke2fr is offline luke2fr  France
Forgot to mention i also changed the dac clock for the flea.
I removed CD02/03, RD02 and XD01. Connected clock signal to pin 28 of DAC through nearest pin of u209 which I also removed and GND in negative pin of CD04.
btw, i'm still looking for what's wrong
Old 6th April 2013, 07:57 PM   #19202
hotiron is offline hotiron  Scotland
hotiron's Avatar
That explains it then your clock is not clocking!! :v
If you give up easily Dont start!!
Old 6th April 2013, 08:24 PM   #19203
the green led on the flea is never on XD
It gets its 18V from an added psu, but it seems ok.
Got to check the flea then.
Old 6th April 2013, 08:39 PM   #19204
hotiron's Avatar
Try swapping the the wire where you removed the crystal. Eg the other pin.
Old 6th April 2013, 08:49 PM   #19205
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
I would go for the non-lit green LED first
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 6th April 2013, 09:27 PM   #19206
hotiron's Avatar
Where's the like button??
Old 6th April 2013, 09:40 PM   #19207
green LED now lights on.
but... lens is not moving at all anymore. It's in the middle of its run, and doesn't come back to start.
If I put a disc, it doesn't spin. It used to before I fixed the flea ( C4 was badly soldered)
Old 6th April 2013, 09:53 PM   #19208
6h5c's Avatar
Ok, do you also have 5V at L1?
Old 6th April 2013, 10:20 PM   #19209
0V at L1 :/
Old 7th April 2013, 07:16 AM   #19210
6h5c's Avatar
Uh oh...
Let's see, do you have:
- about 14V at pin 7 of the AD797 ?
If not, check the orientation of R2 and R8 on the back. They have to be mounted 'North-South' and not 'East-West'.
- about 2V at pin 3 of the AD797 ?
If not, check R3 and R4. These should both carry 2V, they transport the 2V reference voltage from the LED to the opamp.
Marantz CD63 & CD67 mods listHide this!Advertise here!
