| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#19121 |
And it'll be even better if you regulate the new rails
![]() ![]() ![]() This was using +/-8v from the original transformer, but you can use +/-12v regs if you are using a separate transformer and power supply.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard" |
#19122 |
I've seen mention of +/-8v, +/-9v & +/-12v regs used for these. Are the servo driver ICs not bothered about the voltage as long as it's stable?
#19123 |
One Seriously Addicted to Audio and Electronics
No, they can handle upto +/-20V supply voltage, so that's not a problem. But I don't think you'll gain anything from a higher supply, the motor needs only about 4V. The 7812/7912 regulators are more common though, not all suppliers carry the 8V or 9V version.
Ray |
#19124 |
Thanks Ray, I've got some 9v regs on the way.
#19125 |
Is it a KI version? The reason I used 8v is because with the std transformer, there wasn't enough drop out for 9v regs
#19126 |
No, it's a standard normal low spec one.
If my 12v rails are almost completely unused as I have a valve output stage, would it be worth using that to feed these 6 x 9v regs instead? Or is that no comparison to a separate 50va toroidal tx? |
#19127 |
It'll be no comparison. Go big or go home
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S |
#19128 |
#19129 |
Cheers guys. I'll just get some 8v regs for now if they work better with the standard transformer
![]() Also, I'm trying to work out which ceramics and resistors need removing if I'm putting some good quality electrolytics for the local decoupling caps like rubycon ZLG 220uF to the servo driver ICs. Has anyone got info or a diagram for that? |
#19130 |
Actually, I've had a good study of the schematics and I've got it all now, other than the 2 ceramics c146 and c148 being a bit too close together to swap for the ZLG caps and c144 being kind of in the way, but I guess it's nothing a bit leg bending and maybe swapping c144 to the bottom of the board won't sort out. Is that the usual method?
