Marantz CD63 & CD67 mods list - Page 1902 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th January 2013, 02:14 PM   #19011
Default modding CD63SE
I have just completed most of the modding work for my friend's CD63SE
The next thing I will do is to change the clocks for the servo and the DAC by Ray's 2 fleas that I bought from him some time ago.
Eventhough without changing the clocks at the moment the SQ from this player is already very very GOOD
Old 27th January 2013, 07:48 PM   #19012
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Nice work, higlander! I wish mine was that neat.
What 12v regs are you using? They look nice and small.
I've got to start thinking about taking another look at my DOS at some point.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 27th January 2013, 10:00 PM   #19013
Hi Ben|: I used +15 and -15V regulators instead of 12V as most opamps run better at 15V.
The regulators are from Korea with quite good specifications:
ULN-HC78A Ultra Low Noise Positive Regulator 2.5V~30V Output High Current Type | eBay
IMHO they are value for the money regulators and can perform very well.
For the discrete opamps I used Burson as they occupy less space.
Old 28th January 2013, 04:02 AM   #19014
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
hi highlander
i want to ask about your output opamp
- do you still use this schema for output opamp ?
- where do you solder the output, direct to RCA out ?
- or goes before resistor ?
- Can you give me detailed picture ?
Best regards
Old 28th January 2013, 06:19 AM   #19015
Originally Posted by Pocoyo View Post
hi highlander
Best regards
No, I did not try it. With the dual opamps the output to RCA is via a 3.3uF blocking cap and then with a 47R in series.
Old 28th January 2013, 08:36 AM   #19016
UV101 is offline UV101  England
UV101's Avatar
hi highlander
Best regards
There is a problem with the circuit you have posted. The output will be inverted which is one of the reasons for using the 2nd Opamp.
Do as you have done here but take the output from after the 2nd Opamp. The DC value should be almost at this output (but check with a meter on mV scale). Anything less than about 25mV and you don't need the DC blocking cap. The best cap is no cap
I think you've already bypassed the HDAM and muting from what I've seen in a previous post.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 28th January 2013, 09:15 AM   #19017
Hi Ben: A friend of mine has also tried the following discrete opamps and actually the SQ is very similar to Burson but costs much less
http://www.audio-gd.com/Pro/diy/OPA/OPAEN.htm
I was told the seller uses UPS and the shipment is quick.
Old 29th January 2013, 09:19 AM   #19018
UV101's Avatar
I'm sure there are a few details floating around the web about the OPAsun being a copy of the Burson or vice versa??
Old 29th January 2013, 12:08 PM   #19019
OH, I am not aware of that and that might explain why the two products sound so similar
Old 30th January 2013, 04:18 AM   #19020
Ben Hanke's Avatar
Thanks higlander. TBH don't really fancy the idea of discrete op-amps much. I'll be sticking with my LM4562HA until I can finish my DOS.
Copyright ©1999-2017 diyAudio
