Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 25th January 2013, 08:55 AM   #19001
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
From Post 18158, This is the Jumper
Originally Posted by REXTON View Post
Well it's a stock 67SE, this is my 1st attempt at modding a CD player, my domain is usually decks. The only thing I've done so far is to change the power chord with a screen Isotek Elite lead. I'll be dampening the chasis & strut bar with some bitumin pad is I get chance next week. So just to recap
U216/217 out
R617/618 - FORGET ABOUT
R651/2/3/4 - I'll take these out!
C655/6/7/8 - out (the slimlic caps)
I've just got one question and again forgive me for seeming a little slow. I've added a Schematic graphic on this reply. The red crosses are the components which I'm gonna remove for the HDAM bypass, but can you check that I'm linking the output of the opamp stage directly to the player out. So, on R216 I'll be soldering a small piece of silver wire (teflon coated) from the posterior most hole in R216 to the leftmost hole where C658 used to sit for right channel output, and from R217 I'll be soldering another silver wire from the posterior most hole of U217 to the leftmost hole of C657 for left channel output. I hope this makes sense.
I'm hoping to also looking into disabling the headphone circuit (removing C901/902 & U139/140) and also disabling headphone muting circuit by removing QN05-QN08, QN25/25/91/92 and RN27/28. These are mods as detailed in the PDF by R.A. van der Steen. I was looking at doing several mods at once whilst I had the PCB dismantled.
Old 25th January 2013, 09:29 AM   #19002
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by Pocoyo View Post
hey, hey,hey ... post number : 19.000 !!!
New Estimated Post Number 20.000
20.000 – Estimated April 2013 – March 2016
Wow, this thread just keeps on going, amazing!
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 25th January 2013, 09:31 AM   #19003
6h5c's Avatar
Looks good, if you do it this way it will work fine.
Ray
Old 25th January 2013, 09:53 AM   #19004
Pocoyo's Avatar
i will try this before ray just for my reference
as i know in wadia 12 they used 4 x single opamp
and the output can drive balance / xlr too
in my friend CD46 just use 1 double opamp ad826
Old 25th January 2013, 10:06 AM   #19005
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Keep it up.
Please make a simple list of the mods you allready did so we can give you hints on how to proceed.
RC
Old 26th January 2013, 04:06 PM   #19006
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
PSU play =P
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 26th January 2013, 07:26 PM   #19007
nhinstruments
RCruz's Avatar
RC
Old 26th January 2013, 10:57 PM   #19008
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Hi guys,
Im just about to have a play with a cd67 am i right in the dac an servo are clocked together and they are more easily tweaked than the 63 variants ?
many thx alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 26th January 2013, 11:36 PM   #19009
UV101 is offline UV101  England
UV101's Avatar
Yep, only 1 clock in a 67 Al.
Also, there are 2 5v regs as the servo section is regulated as std. Std 67's sound better than 63's due to servo.
Same cap mods apply along with everything from the DAC backwards
63's can be pushed further than 67's due to the more discrete decoder and servo.
Here's one i did earlier!!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 26th January 2013, 11:59 PM   #19010
bikeral10's Avatar
Nice ian ,
Only a standard version ive loads of bits lying around see how it stacks up againt my main player.
thx alan
Marantz CD63 & CD67 mods listHide this!Advertise here!
