Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 11th December 2012, 10:38 PM   #18891
UV101 is offline UV101  England
UV101's Avatar
R124 and 125 form a potential divider from the 5v rail near the servo to create a 2.5v vref. If the values are incorrect the vref will be wrong.
What voltage are you getting at the junction of the 2 resistors? Without the vref, you will have no radial, focus or laser
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 11th December 2012, 10:44 PM   #18892
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
My only question @ highlander why use a cheap clock for the dac when you have a c3 capable of doing dac servo and decoder,?? sorry just my two penneth.
cheers alan
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 11th December 2012, 10:49 PM   #18893
UV101's Avatar
C3 is a single freq Alan. I must admit I'd have the c3 on the dac at 16mhz and another clock at 8mhz on the servo. I guess if you already had a 16mhz clock before you got the C3 its the only way to do it!
Old 11th December 2012, 11:25 PM   #18894
bikeral10's Avatar
Default just thought the c3 was multiple output
Id of done the dac first ,c3 cheap clock after .
alan
Old 12th December 2012, 02:00 AM   #18895
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
will measure after office hour, thank you
Old 12th December 2012, 09:57 AM   #18896
higlander is offline higlander  United Kingdom
Right, you have explained my situation well
Old 12th December 2012, 10:07 AM   #18897
I have an idea in mind to simplify the flow of audio signal. I plan to test and just use the output from the first half of the opamp and connect it to the RCA out. I hope with such a simple circuit the music will have less coloration. Any comment on this approach, please ? I have an un-modded 63SE on my bench and I will have a try and see the difference.
Old 13th December 2012, 05:40 AM   #18898
Ben Hanke is offline Ben Hanke  Canada
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Marantz CD63 & CD67 mods list
Originally Posted by higlander View Post
I wish to mention that the CDP is dead silent and there is no humming noise what so ever even when I crank my amplifier up to its max. volume at 130W !!
Rub it in, why don't you?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 13th December 2012, 07:43 AM   #18899
May be I am the lucky one
I normally plan ahead what to change and cary out the mod one step at a time. What I had done for my CD63 was each time whenever I have changed something I will connect the CDP back to my amplifier and listen for improvements and to identy defects, if any. With this I can easily identify what has gone wrong in the very early stage.
Old 13th December 2012, 07:58 AM   #18900
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Basically, you are bypassing a large section of the analog low-pass filter with this mod. That means lots of high-frequency noise from the DAC can enter your system. This is not a good thing, but the effect of it may vary from system to system. Some have reported a better sound because the extra opamp stage is bypassed, but it can also get worse and cause more distortion. So YMMV... and watch your tweeters!
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Marantz CD63 & CD67 mods listHide this!Advertise here!
