| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1881 |
On a lighter note.
My players browndogs are now fitted with BlackGate NK 0.47uF across +/- rails and 2x BlackGate 10uF from + to gnd and - to gnd via a low loss earth wire to star earth. Its sounding very good but as usual will test over weekend. I will also posts pics of this mod after weekend as i'm sure some of you will laugh. Brent |
#1882 | |
The T in T630mA means they are time lag and they are 630mA fuses. I have 1amp in mine as the 630mA blows on power up due to the demand from caps lol Brent |
#1883 | |
OK cool, il probably order some 1a ones. But i was wondering, is it likely that they have blown, causing no voltage readings from anything after them, or would any of the blown (smokey) parts that blew around QM01, automatically produce no readings throughout. Il try and simplify.lol. If a resistor around qm01 blew, would i still get voltage readings from the 5V reg (Q811)? cheers ad |
#1884 | |
Magneto the Gravity Man
Do you know where the smoke came from??? |
#1885 | |
Pretty sure. I'm not sure if it came from QM01 itself, or one of the components just above it. Still, would that totally screw up the 5V rail or will the blown fuses have prevented me from getting any readings ? p.s. im recieving the player off josh, you cheeky so and so ad |
#1886 |
Don't put 1 amp fuses in mate. I only put 1amp fuses in because mine was demanding 920mA.
If you have a fault and you fit larger fuses you can cause more damage. Brent |
#1887 | |
ad |
#1888 | |
I did a typo too.... the mA was 820mA. Brent |
#1889 |
So, what does the radial servo do?
Its shocking the number of issues we're suddenly getting. |
#1890 | |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| thierry67 |
| Page generated in 0.21921 seconds (67.09% PHP - 32.91% MySQL) with 11 queries |
