Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 21st November 2012, 06:10 PM   #18781
higlander is offline higlander  United Kingdom
Originally Posted by UV101 View Post
To be fair, it does look like there are multiple regs on that vero at the front and although its not that tidy, it will be better. Even lots of std 7805's will be better than 1 single one!!! Did this a few years ago in a Philips cd850 mki
I think that's 11 regs on the dac board lol!!
I'm not sure about all that screening tho. Why not just connect it to the top layer screen rare than wire all round the player.
@UV101: Having seen your thread I went through the listing again and you are most probably right. It was mentioned that five LT1763-5 voltage regulators were used and as you said if that is the case it should be better than using the stock 7805 to supply the +5V to the circuits though the wiring are a bit messy.
For me I have doubt on the usefulness of screening the ICs and what I did was just sticking some copper foils on top of the ICs just for looking good
Old 21st November 2012, 07:19 PM   #18782
I went through the datasheet of LT 1763-5 at the following link:
http://cds.linear.com/docs/Datasheet/1763fg.pdf
It seems that LT 1763 is a relatively simple and effective voltage regulator that can supply a max. output current of 500mA. The noise is quite low about 20uV(rms) while the ripple rejection is about 65dB which is considered marginally good.
I noticed the input power is taken from the digital rail which is about 16V then there will be a voltage drop of 11V in the regulator and would make the actual current output to be less than 200mA. Nevertheless I think this should just be sufficient to supply the current to a single DAC, a single decoder or the servo IC (but definitely not all ICs together).
Not withstanding the workmanship I think the end result must be better than just using a single 7805 for all the +5V circuits.
Old 21st November 2012, 09:41 PM   #18783
bikeral10 is offline bikeral10  United Kingdom
bikeral10's Avatar
Default nice work
nice work ian looks like a porcupines **** lol lol we all aint that bad i flick my solder off a hot blow lamp.
Aint broke it yet but im tryin. ( favs Fast women and even faster bikes)
Old 21st November 2012, 09:44 PM   #18784
bikeral10's Avatar
i personally cover my ics in snake oil 50p a litre works wonders.
Old 21st November 2012, 09:52 PM   #18785
UV101 is offline UV101  England
UV101's Avatar
The voltage drop across the reg is not relevant to the current being drawn by the device(s) it's supplying.
Also the supply is likely to be before the 5v reg which should by about 10v. That rail is for all 5v stuff (analogue and digital) and the positive rail for the servo and driver ic's
I suspect the volt drop,will be in the order of 4v under playing conditions.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 22nd November 2012, 07:50 AM   #18786
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Hi
I contacted the ebay seller about the listing yesterday afternoon asking him to mention the 'other' work he had done. Ian was correct with what we did (probably 2 years or so ago now) and what they had added themselves.
He is a good customer of mine and is selling the cdp on behalf of his brother who no longer uses cds. As far as I am aware the cd player works fine and probably just needs tidying up internally.
regards
Brent
Old 22nd November 2012, 07:56 AM   #18787
Snake Oil is actually very good for you It was the Americans poo pooing the Chinese potion sellers back in the day to make their products look better. That is where the phrase comes from.
Brent
Old 22nd November 2012, 03:30 PM   #18788
UV101's Avatar
Originally Posted by Fidelity Audio View Post
Hi
regards
Brent
Hehehe!!!!
I was right......shame the mrs doesn't always agree!!!!!!
Old 22nd November 2012, 09:43 PM   #18789
bikeral10's Avatar
Default lol@ ian
Hehehe!!!!
mmmm know that one mines american she,s never right if she was i,d know a house full
Old 22nd November 2012, 09:46 PM   #18790
bikeral10's Avatar
Default lol@brent
Brent
just havin a jest @ some of the comments.
cheers brent
Marantz CD63 & CD67 mods listHide this!Advertise here!
