Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2012, 06:05 PM   #18741
Originally Posted by UV101 View Post
If you are getting the mundorfs they will be 25v but the Panasonic tsup's will be 16v.
I prefer the mundorfs but the tsup's are great value for money.
The caps after regs should not be FC's. I use a mix of BG and oscon sepc in my own player but favour Rubycon ZLG 470uF on analogue and Nichicon 330uF solid aluminium where budget is an issue. I also use large value Rubycon ZL or ZLH (1800uF) for the big cap after the main 5v reg.
There are arguments for smaller values for local decoupling, but interestingly, if you look at meridian kit, the prefer larger value local decoupling caps often using multiple 1000uf caps post reg with 470uf close to supply pins ( definately true in the 200 series equipment)
Were is best place to get the caps from found rubycons on ebay but cant find the mundorf. I messaged brent at his shop but had no reply
Old 14th November 2012, 06:29 PM   #18742
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
You can get the Mundorf caps from Parts Connexion
22000uf / 25VDC, MLytic® Audio Grade MLSI (Snap-In) or MLPI (Plug-In) should do the trick.
The discontinued MLSI parts are 40% off at PcX at the moment so it's a very good time to buy from them. Not sure about shipping costs and tax to UK though, so you could also look at Hi-Fi Collective
A word of warning: Be VERY WARY of buying rare or boutique parts on eBay. It's very easy for a crafty manufacturer to dress a cheap capacitor to look just like a Black Gate and make ridiculous amounts of money off them.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 14th November 2012, 07:14 PM   #18743
I believe you live in the UK and then try this:
amplifier valve kits, HIFI pre-amplifiers, speaker kits,AMP Parts, upgrade components
I have just ordered 4 X 22000uF 25V Mundorf and some other caps from this site.
Old 14th November 2012, 07:53 PM   #18744
UV101 is offline UV101  England
UV101's Avatar
Never buy these sort of parts from eBay unless its an eBay outlet for a reputable parts dealer (there are not reputable parts dealers in HK!!!!!)
There really isn't any need!!!
Brent uses his own branded SI caps so he may be able to supply you with his 22,000uF Caps made by F&T who also make the SI caps for Mundorf! Most of mine are SI and either branded as Mundorf, Audio upgrades or Fidelity Audio.
For analogue local decoupling you have Rubycon 470uF 16v
http://uk.rs-online.com/web/p/alumin...itors/7037416/
For digital local decoupling you have Nichicon solid polymer 330uF 6.3v
http://uk.rs-online.com/web/p/alumin...itors/7149543/
Large value FC in the servo - rail C814
SI on the servo + rail C813
SI on the audio rails C803 and C804
For post regulator on the audio you can stay with the Rubycon ZLH C805 and C806
For post 5v reg, I'd use a large value Rubycon ZL C815
Maybe https://uk.rs-online.com/web/p/alumi...itors/7037245/
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 14th November 2012, 09:24 PM   #18745
Buy Aluminium Capacitors Capacitor Al 105deg 470uF 16V 10x12.5 Rubycon 16ZLG470MEFC10X12.5 online from RS for next day delivery.
Buy Aluminium Capacitors Solid Al cap Radial NS series 6.3V 330uF Nichicon RNS0J331MDN1PH online from RS for next day delivery.
Thanks every one about the dodgy components on ebay. I just hope the ha opamps i bought were origonal parts and not copies. Thay were from the uk
Old 15th November 2012, 06:45 AM   #18746
UV101's Avatar
Have you got a link to the advert for the HA opamps?
Old 15th November 2012, 01:24 PM   #18747
Hi uv i cant find them in my ebay history as it was about 18 month since i bought them. Thay were not cheep though about £50 from what i can remember. And thay were from the uk
Old 15th November 2012, 01:30 PM   #18748
lymmlad is offline lymmlad  England
I recently bought 2 @ LME49720HA op amps from Brent and they were a lot cheaper than £50. In fact both together were well under £50.
Old 15th November 2012, 03:23 PM   #18749
Ben Hanke's Avatar
They're about £4 each at Newark/Element14. I'm not aware of any special designations that would make them worth 10X as much. I hope you didn't pay through the nose and get fakes to boot.
Old 15th November 2012, 04:30 PM   #18750
I bought a pair from the US eBay some time ago. Don't know it is fake or not but the SQ is OK to me:
LME49720HA Dual High Performance OpAmp Metal Case X2 | eBay
The only drawback is I have to wait for 1-2 weeks before they arrived from the US
Copyright ©1999-2013 diyAudio
