Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th November 2012, 01:08 AM   #18721
Originally Posted by UV101 View Post
Why buy an overpriced KI on eBay????? I can sell you a badge for £80 if you like!!!!! Thats terrible advise!!
That 67 is more than capable of equalling most DIY 63's if it get tidied up. Would you buy a new car because it needed a new tyre?
Get the main smothers back where they belong, get a large cap in the servo psu and swap the local caps as described a million times before......solid polymer on digital rails and Rubycon ZLh on analogue rails!
The only reason for going 63 over 67 is if you plan to run 2 clocks and use multiple discrete regs! Out the box the 67 out performs the 63 as its servo driver is regulated.
No point in buying a KI unless you want the badge, an SE is the same chassis just not copper plated (copper does look nice tho lmao!!) and the KI has a bigger toroidal transformer. By the time you've done the 1st round of mods, there's nothing in it!!!! In fact, you'd remove th better caps in the KI to replace with something 'better'!!
I'm also interested how Ben should use the scope to track down his mains hum???
What about the external power supply. Shall i keep that for now
Old 11th November 2012, 01:37 AM   #18722
Ben Hanke's Avatar
Send a message via MSN to Ben Hanke Send a message via Skype™ to Ben Hanke
Well, I haven't used one before but I can only measure voltage on my DMM at the moment; I can't see noise / voltage over time. If I can see 60Hz noise spikes on the analogue rails, for example, then that should help me narrow it down a bit, right?
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S
Old 11th November 2012, 07:53 AM   #18723
Ben, did you mention that initially there was no hum but the hum developed sometime at a later stage. Can you recall what had you done to the circuit ?
Old 11th November 2012, 08:06 AM   #18724
UV101 is offline UV101  England
UV101's Avatar
What is the psu? That area needs approx +/-15 v if you are using a single supply from a single 13.4v CB radio psu its not going to work correctly. Can you describe the psu and connectivity. Apologies if I missed this info in a previous post.
Don't worry we will help you get this sorted.
Btw Panasonic tsup 6800uf will fit in the original position in a 67.
In this pic you can see the big caps for the analogue rails in the original position along with the big 22,000uf cap on short leads on its side for the servo psu. This is one I did for a friend and its been back to me twice for additional work!!! It's quite significant now that's for sure!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 11th November 2012, 08:10 AM   #18725
UV101's Avatar
Brent has commented a couple of times on this. He suggested that he had similar problems which turned out to be location of psu components and cabling. Check back through the last few posts.
Other wise you will need to start back tracking through your psu mods to see which rail is upsetting it.
Old 11th November 2012, 01:57 PM   #18726
wdoerr is offline wdoerr  United States
Default Current Power Supply Design
Here is my current design:
-50VA Tx's outside the case, 25VA Tx's inside the case
-RCRCRC filters
-SupperTeddy/Audio-gd Super Regs
You should be able to get 6 PS into the case (this will require several redesigns/repsitioning of the voltage regulators, very tedious).
- 50VA to the clocks
- 50VA to the OpAmps
- 50VA to the Laser (+- 10 VDC)
- 3 X 25 VA to the 5 VDC rails
Also, the cost add up fast. Even using chinese parts and bare pcb's, my final cost will be close to $1000.00 (without shipping).
Old 11th November 2012, 02:51 PM   #18727
-RCRCRC filters
I dont think i could do that i can change caps and stuff like that but that looks too difficult for me. Im better at makeing speaker cabinets and things like that
Old 11th November 2012, 07:16 PM   #18728
Ben Hanke's Avatar
Thanks for your help, Brent and Ian,
Sorry, couple of conversations going in parallel here. I already started the process of backtracking but it's not easy when my player breaks for some other reason every time I take the board out. All of my PSUs are at least as far away from diodes/regs as the stock tx, but there is definitely a lot more wiring in that area behind the CD tray. I'll consider building an external output stage PSU to clear things up a bit.
Beautiful work in that last pic, Ian. It makes me want to start again.
Old 11th November 2012, 09:47 PM   #18729
UV101's Avatar
Thanks Ben. I'm sure you can imagine, it's taken some practice.
I have at least 4 totally dead players due to knackered tracks or dead chips. I've just counted 11 63's and 3 67's that have passed through my hands in 4 years! Still got 4 63's that need to get a bit sorted and sold. I guess practice makes ....well at least you get better!!!
Old 11th November 2012, 10:03 PM   #18730
UV101's Avatar
-RCRCRC filters
Not sure that lot should add up to $1000 but it depends on the clocks and regs you are using.
Looking at the mods you have, you don't need the output caps as there should not be any DC present on the output. Also, personally, I don't like FC caps after the regs. They are great pre reg, but I prefer to use Rubycon ZLG on analogue rails and definitely no question about using anything others than solid polymer on digital rails.
What size cap do you have for the main pre 5v reg smoother. It's important to use a very high value on that rail. Also, have you regulated the servo supply because that is definitely worth doing too.
Page generated in 0.22089 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
