| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#18711 | |
#18712 |
I don't know them, but a cursory search suggests that they are switching power supplies, so not recommended for this application.
Standard voltage for the CD63/67 output stage is regulated +/- 12.
Modified Marantz CD63KI -> Modified PM66KI -> B&W 805S |
#18713 |
Thanks ben yes the mean well power supplys are a switch mode type. Reason i mensioned that brand is i have one for a 41hz amp i have. But i have just ordered a valve amp
#18714 |
I would consider reinstating the original circuitry. It's not difficult. You could download the service manual and upgrade pdf from ray's website. Then run through the op amp section in the upgrade pdf. This would reinstate most of the components then it should be a case of refitting a few wire links and job done.
This kit may help..... http://www.siliconray.com/power-supp...amplifier.html Last edited by mcd99uk; 10th November 2012 at 08:43 PM. |
#18715 | |
#18716 | |
#18717 | |
#18718 | |
#18719 | |
#18720 | |
That 67 is more than capable of equalling most DIY 63's if it get tidied up. Would you buy a new car because it needed a new tyre? Get the main smothers back where they belong, get a large cap in the servo psu and swap the local caps as described a million times before......solid polymer on digital rails and Rubycon ZLh on analogue rails! The only reason for going 63 over 67 is if you plan to run 2 clocks and use multiple discrete regs! Out the box the 67 out performs the 63 as its servo driver is regulated. No point in buying a KI unless you want the badge, an SE is the same chassis just not copper plated (copper does look nice tho lmao!!) and the KI has a bigger toroidal transformer. By the time you've done the 1st round of mods, there's nothing in it!!!! In fact, you'd remove th better caps in the KI to replace with something 'better'!! I'm also interested how Ben should use the scope to track down his mains hum???
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard" |
